Old 02-26-2013, 12:38 PM   #1
sycraft
COTW 5/06/2013
sycraft's Avatar
Transformation to 1LE begins
Car goes in tommorrow for some upgrades, here is a shot of the OE 1LE struts and shocks with the correct shock mounts. The reat of the components will be updated later, as they are a surprise.....
Old 02-26-2013, 12:56 PM   #2
SPCBA
Drives: pleather and Chiclets
why did you choose 1le parts instead of aftermarket? how much did that setup cost you? last time i checked the 1le parts did not have a price from gm yet
SPCBA is offline   Reply With Quote
Old 02-26-2013, 01:46 PM   #3
biggerisbetter
lll
biggerisbetter's Avatar
Drives: 2010 camaro ss L99
^+1
biggerisbetter is offline   Reply With Quote
Old 02-26-2013, 01:54 PM   #4
sycraft
COTW 5/06/2013
sycraft's Avatar
I chose the 1LE because they work and they are much more cost effective than aftermarket. The other option was coilovers, and I did not want to spend that amount for the limited track use it will get. The 1LE is a very cost effective way to get the suspension done right. I will say that I will be using another manufacturers ZL1 specific sways, springs, toe links, LCA's, bump steer kit, ect. more on that once I get that together tomorrow.
Old 02-26-2013, 03:55 PM   #5
Backlash
Backlash's Avatar
Drives: 2010 1SS/RS LS3
where did you get the OEM 1LE stuff at? I am also wanting to go the same route.
My Previous Camaros
92 RS Purple Haze w/Silver Stripes 25th Anv. Heritage Edition
94 Z28 Medium Quazar Blue
My Current Camaro
2010 IOM w/CGM Stripes 1SS/RS LS3
Backlash is offline   Reply With Quote
Old 02-27-2013, 01:09 AM   #6
sycraft
COTW 5/06/2013
sycraft's Avatar
Go to a dealer and have them look up parts to a 2013 1LE and order...
Old 02-27-2013, 01:16 AM   #7
Avalnch
Avalnch's Avatar
Drives: Rally Yellow Camaro+Avalanche
Those parts won't do anything for you until you get your sway bars upgraded.
Vengeance Kaotik Cam, C.A.I., ARH LT, Pypes Cat Back, ZL1 Shifter+2012LS3VERT bushing, Quantum Brake Ducts, JDP Tow Hook Scorch Yellow Trim Kit, Shark Fin, AAC DRLs+ABLs+SMDs, ZTA Rear Spoiler, R.Y. 1LE Splitter. Pfadt coilovers, camber plates, trailing arms, Pegasus Solid Subframe. Pedders ZL1 barz, radius arm & steering rack bushings. BMR adjustable toe-rods. Hotchkis Max Chassis Brace. ZL1 GMPP Driveline Upgrade. TurnOne P/S pump. CTS-V 6 pistons.
447 HP @ 6180 RPM / 418 TQ @ 5100 RPM
Avalnch is offline   Reply With Quote
Old 02-27-2013, 09:28 AM   #8
Cuda7050
Cuda7050's Avatar
Drives: 2012 SS LS3
Please report back on the ride and cornering difference with just the strut and shock change.
Buttonwillow 2:23.736
Sacramento Raceway 12.89 at 112 mph
Thunderhill 2:22.242
Cuda7050 is offline   Reply With Quote
Old 02-27-2013, 11:27 AM   #9
caverman
caverman's Avatar
Drives: '69 SS Convertible
I'm intrested in hearing how they work as well. Approximately what is the cost of the 1LE struts/shocks?
Build Journal
Old 02-27-2013, 03:14 PM   #10
heymatt
heymatt's Avatar
Drives: 2012 IBM 2SS Vert.
Are you gonna have it all back together for the Rally?
LS3/M6 K&N, VMAX throttle body, RX Catch Can, skip shift eliminator, DT shorties and Solo HFC, DRL harness and 5K LED DRL, ZL1 rear sway, 1LE front sway
heymatt is offline   Reply With Quote
Old 02-27-2013, 03:40 PM   #11
nak3dsnake
Drives: 2010 Camaro IBM 2LT/RS M6
Everything cost me about 1K for the whole package. I did a complete conversion with 1LE parts. Except the rear cradle which will be pedders full bushing replacement once the weather gets a little warmer. I also already had the springs and didn't need to buy them.
nak3dsnake is offline   Reply With Quote
Old 02-27-2013, 03:42 PM   #12
nak3dsnake
I paid 70 from the front struts and 180 for the rear shocks.
Old 02-27-2013, 03:44 PM   #13
AKA-22
AKA-22's Avatar
Drives: ELLE-1
t
AKA-22 is offline   Reply With Quote
Old 02-27-2013, 04:29 PM   #14
sycraft
COTW 5/06/2013
sycraft's Avatar
Yes Matt it will be ready for the rally.
Here are the parts installed today, LSR is a pleasure to deal with and their prices are very competitive. LSR Springs, LCA's, Toe Links (Billet) Bump Steer ket ( since lowering the vehicle alters the steering geometry, this returs the steering angles to the correct angle), Front LSR Sway and rear ZL1 sway until the LSR sway comes in. The ride is incredible, corners on rails and very compliant on bumps, no harsh ride at all and turns flat.
