Old 02-27-2013, 02:52 PM   #1
Nitroman28
Nitroman28's Avatar
Drives: 2010 Camaro SS 416/4L80
Anyway to turn ABS off?
When I put my Welds on with 28r/26f tires the ABS goes crazy. Wondering if I could pull a fuse or something to shut it off. Thanks for any help with this.
Nitroman28 is offline   Reply With Quote
Old 02-27-2013, 03:05 PM   #2
TinyToasta
TinyToasta's Avatar
Drives: way too fast....
Pull the fuse #40 (#43 as well if needed)
custom build forged LSA, 379ci, TVS2300@15psi, 696rwhp/688ft-lbs, built by DH Individual, Customkingz, tuned by Jannetty Racing
JRE rough idle cam, JRE ported lower intake manifold, OD cog drive, 6% OD crank pulley, ported ls3 heads, NW102mm TB, 1/2'' RDS spacer, IW 8-rib drive
Pfadt Cradle Bushings, Arms & Rods, Pedders Supercar w/FE4 conversion, ZL1 sways, HE Twin Carbon Street Slayer, ZL1 Rear End (3.73)
CTS-V Brake upgrade, Street: 22'' Vossen CV1, Strip: 18'' Forgestar F14 on MT Street Radials
TinyToasta is offline   Reply With Quote
Old 02-27-2013, 03:22 PM   #3
Nitroman28
Nitroman28's Avatar
Thanks for the reply, I'll give it a try. Wasn't sure if they would mess with anything else. Just don't wanna get to the end of the track and have the ABS go crazy.
Old 02-27-2013, 03:26 PM   #4
TinyToasta
TinyToasta's Avatar
I'm sure wether to head towards the end of the track with the ABS completely shut down is such a good idea either...
Old 02-27-2013, 08:34 PM   #5
Parabolica
Drives: 2011 2SS
You'll lose stability control and traction control as well. Probably want those off at the track, but just letting you know.
Parabolica is offline   Reply With Quote
Old 03-04-2013, 10:24 AM   #6
Nitroman28
Nitroman28's Avatar
Pulled the fuse 40/43 and fixed the problem, Wish I would have pulled those when I first started racing the car, Don't have to mess with turning off T/C anymore. And car stops fine with the ABS off.
Old 03-04-2013, 01:50 PM   #7
MikeOD
Drives: 2010 M6 2SS
Any lights on the dash from pulling the fuses?
2010 Camaro SS M6. Heads/Cam/Intake/Headers/Exhaust/Suspension
MikeOD is offline   Reply With Quote
Old 03-04-2013, 02:10 PM   #8
Nitroman28
Nitroman28's Avatar
Yea. Like a Christmas tree. I don't have to stock radio so I don't know if the warning chime was going off. I have that turned off. Lights on was Brake, ABS, StabiliTrak.
Old 03-04-2013, 04:11 PM   #9
MikeOD
Drives: 2010 M6 2SS
That's how my 4th gen was too...had to cut the traces to the LED's on the back of the circuit boards...pain in the ass, but was worth it in that car.
Old 03-04-2013, 04:16 PM   #10
fielderLS3
fielderLS3's Avatar
Drives: 2016 Mazda6, 2011 Mustang 5.0
I had to pull the ABS fuse on my Alero over 3 years ago. No chimes, but the ABS and Brake light are on, but oddly enough, the traction control lights are not, even though I know that is now inactive, too.
The brakes will function without it. You just have to be aware that in a panic stop, you'll have to pump them or threshold brake yourself to keep the wheels from locking.
2022 1SS 1LE (Arrived 4/29/22)
"The car is the closest thing we will ever create to something that is alive."
. 2022 1SS 1LE (Coming Soon)
fielderLS3 is offline   Reply With Quote
Old 03-31-2014, 06:33 PM   #11
bbarnett
Drives: unknown
Does anyone know how the proportioning works once ABS is disabled?
I'm moving from the VW world, and for example:
1) 2007 Jetta 2.0T - had a fuse for ABS pump, and a separate one labeled brake pump. When the ABS pump fuse was pulled, you could still feel the rear-wheels being proportioned when necessary. All traction control, ABS etc was completely disabled otherwise
2) 2010 EOS 2.0T - VW no longer had a separate fuse for ABS at all. When I did some *deep* research, I located the ABS control unit, which was manufactured by a third party.. not a VW part (and, not surprising in this day and age)
Anyhow, I disabled ABS by removing the left-front ABS sensor wire, and traction control, ABS, EDL, etc were all disabled. However, rear-wheel proportioning still worked.
In both cases, you can feel the rear wheels with mild stutter, but it's not like an ABS stutter, and definitely rear-wheel only. The best way to describe the feeling, is that the car itself is just throttling rear-wheel brake pressure, and the stuttering is indicative of the braking system reducing braking pressure via stuttering.. and without the use of sensors. EG it's providing the same function that an older style manual proportioning valve would...
So...
The above makes complete and perfect sense, in that, you don't want an ABS fuse to blow, or a sensor to go, and then have 50/50 brake split. It would certainly lead to potential additional accidents during such an event.
Does anyone know what GM does, or... what the Camaro does? I'm not looking for speculation, although I do appreciate that we all like to.
I guess what I'm asking is -- some people are disabling ABS. Some of those people must have had events where proportioning would be beneficial.
Has anyone had any real-world experiences that makes them believe that proportioning exists with ABS disabled?
bbarnett is offline   Reply With Quote
Old 03-31-2014, 08:41 PM   #12
oldfriend
Drives: Fiat 500 E
It always does , except that one time that ,,,,,late
Old 03-31-2014, 08:45 PM   #13
Nitroman28
Nitroman28's Avatar
My first vehicle was a 67 Chevy short wide. I think I can handle it. I could unhook the front brakes and still have better brakes then the 67.
Old 03-31-2014, 09:12 PM   #14
bbarnett
Drives: unknown
Nitroman28...
Any ideas on the proportioning of front to rear brakes, without ABS? Do you find the rear end slides around a bit more when braking?
Or, do you notice any pseudo abs stutter like I described above, on the rear end only?
