Old 03-05-2013, 08:44 PM   #1
coptzr
Resistance is futile
coptzr's Avatar
Drives: Anything thats fast
Tire and wheel size......
Gonna be running a set of Black 1LE 10 spokes soon..I hope. What size tires will work best?? Got Mich pilots on my hurst wheels, 305's and 255's....fit??
Modifications (so far)
Edelbrock E-Force supercharger
JRE fuel system upgrade
Edelbrock CAI
VMS stage 2.5 cam kit
SLP LT's, no cats
NPP muffler's w/x-pipe
Tuned at Vector Motorsports
606 RWHP and 567 RWT
Black 1LE 10 spokes.
Hotchkis drop springs.
coptzr is offline   Reply With Quote
Old 03-05-2013, 09:05 PM   #2
OzzySS
OzzySS's Avatar
Drives: 2013 2SS/1LE, 2004 Cavalier
Have you got the same setup (10s & 11s)? The 1LE runs 285/35 on all 4. Think some other guys have already gone up to 305s, I wouldn't think 255s would work. Good luck getting the wheels!
Build thread linked in the pic...
OzzySS is offline   Reply With Quote
Old 03-05-2013, 09:42 PM   #3
So Cal Camaro
So Cal Race Team
So Cal Camaro's Avatar
Drives: 2013 Camaro
The Michelin Pilot's, I think run a little bigger so might be ok, but I would say a minimum of 275 would probably be the smallest I would want to run on the front 10's and the rear I run a Nitto 315/35-20's
So Cal Camaro is offline   Reply With Quote
Old 03-05-2013, 10:02 PM   #4
tramtwo
tramtwo's Avatar
Drives: 2021 1LE
Any suspension correction to accommodate the larger patch out back?
tramtwo is offline   Reply With Quote
Old 03-05-2013, 10:17 PM   #5
So Cal Camaro
So Cal Race Team
Drives: 2013 Camaro
Just what Pete recommended, Pedders Supercar Coilovers, ZL1 Sways, HD Subframe Bushings, Radius Bushings...it's all good...
Old 03-05-2013, 10:27 PM   #6
tramtwo
tramtwo's Avatar
Drives: 2021 1LE
Man that is one sweet setup... :jealous:
Old 03-06-2013, 01:37 PM   #7
hammer94
Drives: 2013 Camaro 2ss/ 1LE
So Cal Camaro, why the ZL1 sway bars? I'm curious as I have seen a couple 1LE owners do that. The 1LE already has 27 mm front and 28 mm rear, and I think they are both solid. I was also thinking that they are either bigger or the same size as the ZL1 which I think has like a 27mm on the rear? Maybe I'm wrong but it seems like the money on the sways would be better spent else where as the 1LE already has great sway bars? Just wondering!
hammer94 is offline   Reply With Quote
Old 03-06-2013, 02:51 PM   #8
So Cal Camaro
So Cal Race Team
Drives: 2013 Camaro
The front bar from Pedder's is adjustable, the 1LE bar is not(Both 27mm)...and the rear Pedder's ZL1 rear bar is 32mm, so larger than the 1LE 28mm bar, to help with handling since I am running the larger tire on the rear.
Old 03-06-2013, 02:54 PM   #9
So Cal Camaro
So Cal Race Team
Drives: 2013 Camaro
Thanks, Just trying to get it set up to run in a bunch of events this year that include some big road courses.
