Old 03-10-2013, 03:21 PM   #1
12 ZL1 #1725
12 ZL1 #1725's Avatar
Drives: 2012 ZL1 Black 6M
A QUIZ for an Aeroforce gauge???
Ok. I put in the Aeroforce Dual Gauges... Now the question is what parameters should I scan?? Also where are the tempatures being read at on the car. 1)I know IAT is internal air temp... But IAT 1 is where? Also what would be considered too high? 2) IAT 2 is where? Also what is considered to high? 3) rail pressure? Is fuel rail... but what should it read? What would be a parameter for this reading? From too low to... Too high? Should I be reading it in (g) or (di) 4) ambient air is the air outside... Before or at filter? Correct? 5) MAF.. mass air flow...? what should it read? 6) MAF freq 1 What is it? 7) injection duty 1 & 2 What is it and what should it read? 8) fuel trim cell What is it. And what should it read? 9) A/F cmd what is it and what should it read? Also any suggestions or RECOMMENDATIONS on what I SHOULD BE SCANNING AND KEEPING AN EYE ON... WOULD APPRECIATE!!!!! This is what I have set so far.... Boost nigh/PSI.... A/F RATIO..... INTAKE AIR.... IAT 2.....AMBIENT AIR.... IGNITION ADV.... KNOCK RETARD.... KNOCK COUNTS.... SHIFT TIME IN ms.... FUEL LEFT.... Please let me know if there are any others that might be helpful that I'm not using!!!!
Sit Back and Enjoy The Ride!!
12 ZL1 #1725 is offline   Reply With Quote
Old 03-10-2013, 07:56 PM   #2
12 ZL1 #1725
No one??? Afraid of tests?? Lol! Come on!!! Lmao!!!!
Old 03-10-2013, 08:19 PM   #3
12 ZL1 #1725
Gauges installed...
Old 03-10-2013, 08:20 PM   #4
Supercharged SS
Drives: 2010 Camaro
It won't read the A/F without a bung in the exhaust.
Old 03-10-2013, 08:24 PM   #5
1MtnGoat
1MtnGoat's Avatar
Drives: '12 SIM ZL1, 1 of 49
I mostly scan boost and H2O temp on my top gauge. The annunciator is set to alarm on 220*+ H2O temps. The 2nd gauge is set on tranny temp and oil pressure with the annunciator to alarm at 20 psi or less on the oil. I have other parameters set on each gauge but I do not regularly scan them. If I remember correctly IAT1 temps are at the MAF sensor and IAT2 temps are in the intake manifold after the blower. Read a good book on tuning fuel injection and it will help you understand what these parameters are. I would take pages to explain it all here. Scan what you want to know about.
Under Hood - Painted strut bar ends w/custom Polished Stainless mounting hardware, E2 CC, RotoFab CAI, ZL1 underhood decal, Amsoil oil, Black billet strut covers, Metco pulleys, intercooler reservoir, JRE 75 RWHP package.
Chassis - Hawk ceramic brake pads, ZL1 wheel decals, Amsoil fluids
Interior - A pillar gauge pod w/Aeroforce Interceptor gauges, Polished ZL1 speaker rings, ZL1 mats and console lid, Custom GPS mount
Exterior - 3M clear bra, LED driving lights, PIAA Plasma Ion yellow fog lights, Window tint, CF bowties, Technostalgia sequential tail lights
1MtnGoat is offline   Reply With Quote
Old 03-10-2013, 08:29 PM   #6
12 ZL1 #1725
Ty! That's a start!
Old 03-10-2013, 08:30 PM   #7
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
IAT 1 is in the MAF sensor, IAT 2 is post supercharger, injector duty cycle is a measure of how hard the injectors are working for a given setup. Most cars after a few airflow mods + boost mods are at 100% duty cycle on stock injectors which means the injectors need to be swapped for larger injectors (63lb or ID850s most popular). A/F cmd is the air/fuel ratio commanded by the ECM which keeps the fueling consistent. Many of those parameters will be not very useful but interesting to see once. I think knock retard, IAT 2, Boost, ignition advance, IAT1 are good items to watch. Research the MAF flow rates to see what normal values are supposed to be.
'17 ZL1 A10 Mosaic Black PDR/Nav 2:03.08 VIR Full 11.003@129.2 1.75 (sold)
'15 Z/28 #325 Black a/c & stereo. 2:10.1 VIR Full (sold)
'12 ZL1 A6 Black 10.52@131 1.55 60' 2:13 VIR Full (sold)
Stephen12ZL1 is offline   Reply With Quote
Old 03-10-2013, 08:42 PM   #8
12 ZL1 #1725
Thank you!!! Really appreciate the information!!! I know when I had the motor work done they put in FAST injectors.... I think 89lb injectors....
Old 03-10-2013, 11:19 PM   #9
potwasher
Banned
Drives: gen5
jamie is the bung expert.
potwasher is offline   Reply With Quote
Old 03-11-2013, 07:53 AM   #10
Drew P
Drew P's Avatar
Drives: Camaro ZL1
I watch IAT1 IAT2 Knock Retard and alternate between boost and timing advance.
Drew P is offline   Reply With Quote
Old 03-11-2013, 02:31 PM   #11
12 ZL1 #1725
Did some checking and aeroforce web site says A/F Ratio will work with wideband ECM, and if I'm not mistaking the ZL1 has a wideband ECM.... Can someone confirm this? Ty!!!!!
Old 03-11-2013, 03:04 PM   #12
RoketRdr
RoketRdr's Avatar
Drives: 2010 Duramax; 2012 CTS-V Coupe
You have to install the wideband O2 sensor in the exhaust. Aeroforce has these on their sight.
RoketRdr is offline   Reply With Quote
Old 03-11-2013, 06:30 PM   #13
LBV
LBV's Avatar
Drives: G8 GXP manual
Set the warning for sure on knock retard - that's what'll kill your engine.
Yes, all it takes is 1 bad knock but atleast you'll know if the tune is off before you get there.
2009 GXP, Manual with Sunroof
Zeta platform, LS3,TR6060 tranny ... ya, it's a 4-dr Camaro!
Borla cat-back, H&R springs, & Sprintbooster & I love it!
LBV is offline   Reply With Quote
Old 03-03-2015, 10:30 PM   #14
EvilZL1
Snake Eater
EvilZL1's Avatar
Drives: 2012 AGM ZL1
Originally Posted by 12 ZL1 #1725 View Post
Gauges installed...
how did you get the pillar to look like this?
Build Thread: http://www.camaro5.com/forums/showth...95#post8351295
Make sure you don’t forget to subscribe to my channel! More content on the way. Like, share with your friends
https://www.youtube.com/channel/UC9Z...sP2wjsLLFeP1zQ
Follow me on instagram:
http://www.instagram.com/snkeatr/
EvilZL1 is offline   Reply With Quote
