Old 03-11-2013, 07:48 PM   #1
BigMatt
2010 Camaro 2 SS/RS M6
BigMatt's Avatar
Drives: 2010 Camaro SS/RS
Send a message via AIM to BigMatt
DIY Clutch and Rear cradle removal
Here is my write up of how to remove your rear cradle, remove rear cradle bushings, remove your driveshaft, transmission, clutch, and replace them all. I'm still in the middle of doing all of this so I will update it as I go. The first couple pics are just some of the goodies I have to put on my car during this project. See sig for the rest.
First up is to jack the car up with enough ground clearance to remove the transmission. I believe I read on here that you need about 18" of ground clearance.
Next I removed the exhaust
I forgot to take pics of how I removed the rear cradle bushings but I used a trick I learned on here, by heating up around the bushing with a propane torch and putting a socket above the bushing and jacking up the cradle and using the weight of the car to push out the bushing. I had them all out in about 20 mins, it was a piece of cake.
Next up I removed the driveshaft using a t60 torx bit and an 18mm(pretty sure) wrench, make sure you mark the ds so that you can put it in the same way you took it out. I'm replacing mine with a dss 1000hp aluminum piece but I showed you how to mark it in case you reuse yours.
After the driveshaft was out I unbolted the calipers and brake line and hung them up using zip ties.
Forged LS3, FED M311 heads, CAI Inc, ARH 1 7/8, Corsa Xtreme, Taylor Wires, MGW Shifter, Street slayer twin carbon clutch, Tick braided clutch line & speed bleeder, ZL1 Diff Swap, BMR Split drop, Sway Bars, Trailing Arms, Toe Rods, Pro bushing kit, Carslyle racing 15in conversion, Whipple, LPE dual fuel pumps, Rx catch can, Id1300x, Alky Control
BigMatt is offline   Reply With Quote
Old 03-11-2013, 07:49 PM   #2
BigMatt
BigMatt's Avatar
After the driveshaft was out of the way you can get access to the parking break cable. You remove this by simply pulling the ball down through the hole (thats what she said)
Next just follow the parking break lines and remove them from their holders there are three on each side.
There's a connector on the passenger side that needs to be unclipped. The small tab on the connector pulls back toward you and just slides out.
Then I unbolted the rear coils from the body using I think a 15mm socket.
After you make sure you disconnected everything I just put a jack under the center of the diff and pulled it straight out. It stayed perfectly balanced on there just be careful lowering it down.
Old 03-11-2013, 07:49 PM   #3
BigMatt
BigMatt's Avatar
Next up on the list is to remove the shifter from the transmission. Luckily I already have the mgw shifter so all I had to do was pull down the dust boot, pull out the clip using a flat head screwdriver and unbolt the shifter arms from the side of the shifter assembly.
The next few shots are just all of the sensors and the cooling lines that have to be removed from the transmission. After they are all removed I moved the entire harness up and over to the passenger side of the transmission. I also removed my O2 sensors just so they wouldn't be damaged when I pulled back the transmission.
There are also some places where the harness is "pinned" to the transmission, all I did to remove these was take a flat head screwdriver and pop them out
Before I removed the clutch fluid line I went ahead and drained out the reservoir and capped off the clutch line. I'm going to be putting a separate clutch fluid reservoir and tick speed bleeder and braided clutch line so I figured I'd do it now rather than dumping fluid all over the floor from underneath.
Old 03-11-2013, 08:29 PM   #4
BigMatt
BigMatt's Avatar
Thats as far as I got today, I'll post more as I get it done
Old 03-12-2013, 02:49 PM   #5
Jerry7297
Jerry7297's Avatar
Drives: 2018 2SS/ 1LE
Very useful info. Well done man, thanks for the good pics and procedures. I will be doing my rear cradle bushing soon and want to try the method you stated. Cause I helped some buddies do a different car and it was not that easy.
Jerry7297 is offline   Reply With Quote
Old 03-12-2013, 02:59 PM   #6
biggerisbetter
lll
biggerisbetter's Avatar
Drives: 2010 camaro ss L99
gonna be awesome man keep up the good work
PERFORMANCE
DYNATECH LT 1 7/8 HEADERS, CATLESS MID PIPES, CORSA CATBACK, CAI. COLD AIR INTAKE w/ SCOOP, 1LE 3:91 GEARS, LETHAL RACING PROWLER CAM, LETHAL RACING DYNO TUNE, ENERGY CRADDLE BUSHING INSERTS, PADDLE SHIFTER RELOCATE KIT, 449RWHP/438TQ
APPEARANCE
COPO HOOD, ZL1 SPOILER, SLP BLACKOUT PANEL, PLASTI DIP WHEELS, HERITAGE GRILL, RETRO SS EMBLEMS, WEATHER TECH FLOOR MATS, ORANGE STITCHING
biggerisbetter is offline   Reply With Quote
Old 03-12-2013, 07:20 PM   #7
BigMatt
BigMatt's Avatar
OK so after you get the harness off to the passenger side (I tucked mine behind my headers) I pulled down the black covers over the transmission cooling lines. Under the covers is a C clip that needs to be removed in order to pull the coolant line out.
Then I unbolted the coolant line from the bottom of the tranny
I went to harbor freight this afternoon and picked up this tranny jack for $80, some people said it wasn't necessary but I found it very helpful. It made sliding the tranny out pretty easy.
After you unbolt the transmission crossmember slowly lower the back of the tranny down until you can see the top bolt of the bell housing, This is where you need the 4ft extension and 15mm swivel socket.
I used a telescoping magnet to get the bolts. This is what I'm going to use to get the bolts back in also.
After you get the 8 bolts out slide the transmission back. I had to turn it counterclockwise so that the bellhousing on the drivers side would clear the tranny tunnel. You don't need to turn it a lot. Just enough to get it past.
Once you get that out of the way you can pull out your old clutch by unbolting the clutch from the flywheel, then since I was replacing mine with a Street Slayer Twin Carbon I pulled off my flywheel too.
My clutch looked almost brand new, even though it has 30,000 miles on it and this was the clutch that I learned how to drive stick on. 10,000 miles of which were cammed with JRE smooth idle
Next I bolted on my new (much lighter) flywheel and lined up my clutch plates, making sure I have the plates facing the right way, then I bolted up the cover.
This is as far as I got tonight, I'm going to keep this thread going with the LPE fuel pumps next.
Old 03-12-2013, 08:37 PM   #8
Stealth 2010 2SS/RS
Stealth 2010 2SS/RS's Avatar
Drives: Black 2SS/RS M6
Good work. You got one hell of a shopping list there.
2010 LS3 2SS/RS M6
AirAid Cold Air Intake, AAC LED sidemarkers, AAC P13w plasmas drl, Kook's Custom 1-7/8" Headers, Corsa Hybrid Exhaust
JRE 445 Cam Package, JRE SCT Tune, RX Catch Can and Breather
Tech AFX Heater Hose Relocation Kit, Black Chrome Wheels
Pfadt trailing and toe arms, Pfadt solid subframe mounts, Pfadt diff bushings, Street Slayer Twin Carbon
Technostalgia Camaro LED taillights, CTS-V Front Brakes, Powder Coated Calipers By ME
MGW Short Throw Shifter
Complete ZL1 Rearend Swap
Stealth 2010 2SS/RS is offline   Reply With Quote
Old 03-12-2013, 08:43 PM   #9
BigMatt
BigMatt's Avatar
Yep lots of work done, lots more to do haha. Thanks for the tips they helped a lot!
Old 03-12-2013, 09:26 PM   #10
Medi0cr3
Untamed Performance EPT
Medi0cr3's Avatar
Drives: 2011 2SS
Nice! Now for the hard part! Reinstallation :P
Night Fury Cam
Borla LT Headers and Borla Cat Back ATAK
9in. diff with 4.11's, DSS Axles, and Alum Shaft
Hurst Short-Shifter; Ideal Garage Master Cylinder
H-E Street Slayer Twin Billet Clutch
BMR: Adjustable; Trailing Arms, Toe Rods, Extreme Sway Bar. BMR Subframe Bushings.
Strange Rear Coilovers and mounts
Tuned by Rhino79
Medi0cr3 is offline   Reply With Quote
Old 03-13-2013, 09:12 AM   #11
BigMatt
BigMatt's Avatar
Yea it's going to be fun getting it back in haha. I'm hoping that tranny jack makes it pretty easy though.
Old 03-13-2013, 11:07 PM   #12
Stealth 2010 2SS/RS
The tranny jack makes life easy, you won't regret getting it.
2010 LS3 2SS/RS M6
Old 03-14-2013, 06:55 AM   #13
BigMatt
BigMatt's Avatar
Yea it was definitely worth the investment. I got it all back together last night. So I'll post up more pics when I get home from work.
Old 03-14-2013, 12:57 PM   #14
Stealth 2010 2SS/RS
I'm going to use the tranny jack when I do my ZL1 diff swap. That diff is much heavier then the stock one. Good to see everything went back together.
2010 LS3 2SS/RS M6
