03-11-2013, 11:06 PM | #1 |
Drives: 2013 Camaro LFX Join Date: Jan 2013
Ok, Can someone please explain fog lights on the LS
I have a 2013 LS and would love to put fog lights in it. So far I think I need a harness but have a few questions I cannot find answers for.
1) Do I NEED a harness? Is there anyway to wire without one (bulb type idk) and if so how is it done. 2) I read somewhere the Tahoe fog lights work with the Camaro and are much cheaper. Plus I read they come with a working harness. Would these work and HOW would I hook them up http://www.ebay.com/itm/CLEAR-07-12-...4941da&vxp=mtr Thanks to anyone who can help |
03-11-2013, 11:15 PM | #2 |
Drives: Camaro ZL1 Join Date: Aug 2012
Hit the search button at the top.
-2013 Camaro ZL1-Black Stripe Package-Ambient Light Kit-Subwoofer Package-Sunroof-Suede Package-NAV MYLINK-MANUAL BABY-Dual Vented Fenders-Exposed Carbon Fiber Insert
-Black 10 Spoke Wheels 604 RWHP 602 LBS/TQ |
03-11-2013, 11:18 PM | #3 |
Drives: 2012 Chevrolet Camaro Join Date: Aug 2012
yes the tahoe lights will work but if u do get a harness for them they wont work unless you go to the dealer and get them programed to work
option 2 would be to wire to a switch or your running lights |
03-11-2013, 11:20 PM | #4 |
And how exactly to you wire to running lights. I'm not understanding the concept.
03-11-2013, 11:26 PM | #5 |
Drives: 2010 VR 2LT/RS A6 Join Date: Feb 2013
I will save you a search... IMHO,
...here is one great vendor with a harnesses for what you want to do:
http://www.gen5diy.com/index.php?rou...&product_id=67 The above link is just an example... a DRL1 harness. Search his site. |
03-11-2013, 11:38 PM | #6 |
Ok thanks guys. Can someone explain what "tapping into side markers" means?
I think that is the cheaper way to go. |
03-11-2013, 11:41 PM | #7 |
You serious Clark?
Drives: 2012 Summit White 2LS Join Date: Jul 2012
Installed them on mine last week. Cost 140$ in parts and about an hour of time.
Off On Close up Also 5,000K HIDS DDM Tuning http://www.camaro5.com/forums/showthread.php?t=281962
03-11-2013, 11:47 PM | #8 |
@hayden
Sorry for asking a million times but how did you power them. I understand how to get them in the car but wiring confuses the hell out of me. I feel like I'm gonna have a "aha" moment soon. |
03-12-2013, 12:04 AM | #9 | |
You serious Clark?
If you are using LED bulbs that do not require much power to run. You can simply T-Tap into the side marker. Running a positive wire from your bulb then tapping it into your side marker positive wire using a "T-Tap". Your just connecting the positive wire from your bulb to the positive wire on your side marker. Same way with your negative off the bulb. Pretty straight forward. No need to remove fascia either.. Just do it from wheel wells. Torque screw is the only tool!
03-12-2013, 12:14 AM | #10 | |
03-12-2013, 12:18 AM | #11 |
You serious Clark?
Basically just crimping, I added tape to help further secure.. and clean things up a tad bit.
03-12-2013, 12:24 AM | #12 |
Drives: 2014 1LS M6 Supercharged Join Date: Feb 2011
Go to an Auto Store, Tell them you want buy a connector to tap into a wire and let him show you how to use it.
03-12-2013, 12:25 AM | #13 |
t-tap--you crimp the blue part on the stock running lamp wires..and you crimp the white part on the end of the fog light wires(you'll have to cut the existing harness connector off of the fog light) and the white part plugs into the blue part
03-12-2013, 12:37 AM | #14 |
Drives: 2012 1LS Camaro (Victory Red) Join Date: Sep 2012
I was under the impression that the LS harness does not have the ability to add fogs and they must be wired to the side lamps. I've done a lot of research on this and have yet to see otherwise. Anyone want to clear that up? Thanks
