Tweety
Drives: 2010 Camaro 1LT RS Join Date: Dec 2012
2010 1LT RS.
About 2-3 weeks ago I got an axle-back installed. Everything was fine until 2 days ago. The Check engine came on on Sunday. I drove it home and was fine. Monday I went to subway and the check engine light didnt come on. Today, Tuesday, I tried to autostart the car; it didn't work. I went outside and turned the key and it started up just fine but the check engine light was on again. Whats up with my Camaro???
Banned
Drives: 2010 2SS/RS A6 & 2011 1LT/RS Join Date: Apr 2012
Need to find out what code/codes it is throwing. Im confident in saying the check engine light is NOT caused by your axle back though.
lll
Drives: 2010 camaro ss L99 Join Date: Jan 2013
i would get those check engine light troublecodes asap. thats the first thing you should do not just hope they dont come back on next time you drive it. they will check them for free at any parts store.
PERFORMANCE
DYNATECH LT 1 7/8 HEADERS, CATLESS MID PIPES, CORSA CATBACK, CAI. COLD AIR INTAKE w/ SCOOP, 1LE 3:91 GEARS, LETHAL RACING PROWLER CAM, LETHAL RACING DYNO TUNE, ENERGY CRADDLE BUSHING INSERTS, PADDLE SHIFTER RELOCATE KIT, 449RWHP/438TQ APPEARANCE COPO HOOD, ZL1 SPOILER, SLP BLACKOUT PANEL, PLASTI DIP WHEELS, HERITAGE GRILL, RETRO SS EMBLEMS, WEATHER TECH FLOOR MATS, ORANGE STITCHING |
Tweety
Codes? So just go to a part store and they can check for the codes?
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: Really Slow Join Date: Apr 2010
yeah, find an autozone. they can give you the code for what the problem is. they will hook up an OBDII reader to your car. takes 2 minutes. autostart doesn't work with a CEL. once you figure that out, your autostart will work again.
#6 |
Retarded One-Legged Owl
Drives: 2010 Black Camaro 2SS Join Date: Oct 2008
Indeed.
And as long as a check engine light (CEL) code is showing up in the car's computer, you cannot remote start your car
#7 |
i'll put a dollar down, that it's the fuel cap wasn't closed right.
#8 |
Tweety
Im in school right now. I'll check the gas cap in an hour or 2. Hopefully thats what it is. If not then I guess i'll be going to autozone soon!
#9 |
i'm not 100% sure, but if it is your fuel cap, you might have to drive around for a while, before the CEL clears. doesn't hurt to go to the auto store and get a code reading. it's free.
#10 |
Don't tread on me
Drives: 23 Sierra X31, Past 2017 Fifty 2SS Join Date: Nov 2012
Occasionally my keyless start will start cranking then stop. Then I get in to see the low fuel light on
#11 |
lll
if it is the fuel door the autparts store can also clear the code for you.
PERFORMANCE
#12 |
Tweety
Bad news. I dont think it was the gas cap because the light didn't go off. Guess i'll go to autozone tonight...
#13 |
Tweety
Well now im confused... The check engine light is now off. Should I just forget about it or what?
#14 |
Banned
If its off now just drive it around like you normally would and see if it comes back.
| Tags |
| check engine light, problems |
