![]() Drives: 2010 camaro ss rs Join Date: Mar 2010
LSX 427 FOR SALE
AS THE TITLE SAYS
for the price im looking for 12500 OR BEST OFFER any other questions just let me know Crank: Callies Dragon Slayer 4340 forged steel, 4.000” stroke, internal balanced front and rear Rods: Callies 4340 forged I-beam, 6.125” length, floating pin, ARP 2000 rod bolts. Pistons: Diamond 2618 forged Turbo pistons designed for boost up to 30 psi, New options: Hard anodized coating, H-13 Upgraded wrist pins, gas port piston and round wire locks. Rings: Total Seal Stainless Steel rings set gapped for boost Bearings: Clevite H-series main and rod bearings Lifters: GM Cadilac Racing Hydraulic Roller Camshaft: Comp Cams Hyd Roller Cam with Turbo Specs Pushrods: Comp Cams Hi Tech Series Heads: Trick Flow 245cc CNC ported heads with 6 bolts per cylinder, Inconel Exhaust valve and valve springs good up to .650” lift Rocker Arms: Jesel Roller Rockers Timing Set: Manley billet double roller, 9 key way bottom gear and Torrington bearing Oil Delivery: Melling Select Performance Gasket Set: Cometic MLS head gaskets Head Studs: ARP Pro Series Head Studs for 6 bolt heads Intake System: Edelbrock Victor Jr intake ported to match heads, 90 degree elbow, 92mm FAST throttle body, 95 lb fuel injectors, Billet Fuel Rail kit with fittings Covers: GM factory oil pan, timing cover, rear seal cover, lifter valley cover, valve covers |
bump
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro SS/RS 6spd Join Date: Sep 2009
Not a bad price for this! What's the HP rating? Just curious!
we haven't dyno the engine it self but we dyno it with a twin turbo and it came up with 1600 HP
![]() Drives: 2010 LLT victory red Join Date: May 2012
I will be able to take this off your hands in a few months...just wish deals closed sooner then later
Sent from my EVO using Xparent Red Tapatalk 2 |
#6 |
PM sent
and a bump |
#7 |
Drives: 2012 Camaro RS, RX supercharged Join Date: Dec 2009
That is a motor built with ALL the right pasts.
#8 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2012 45th Vert, 2011 4x4, 9sec Vega Join Date: Mar 2012
That's some car porn right there. GLWS.
I feel it only fair to warn you, I have a black belt in CAPS LOCK.
#9 |
bump
#10 |
lll
Drives: 2010 camaro ss L99 Join Date: Jan 2013
PERFORMANCE
DYNATECH LT 1 7/8 HEADERS, CATLESS MID PIPES, CORSA CATBACK, CAI. COLD AIR INTAKE w/ SCOOP, 1LE 3:91 GEARS, LETHAL RACING PROWLER CAM, LETHAL RACING DYNO TUNE, ENERGY CRADDLE BUSHING INSERTS, PADDLE SHIFTER RELOCATE KIT, 449RWHP/438TQ APPEARANCE COPO HOOD, ZL1 SPOILER, SLP BLACKOUT PANEL, PLASTI DIP WHEELS, HERITAGE GRILL, RETRO SS EMBLEMS, WEATHER TECH FLOOR MATS, ORANGE STITCHING |
#11 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro SS/RS 427ci Join Date: Jul 2009
Badass motor for the price
#12 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 SS , 1970 Z-28, 2002 Avalanche Join Date: Aug 2009
If I could rob a bank and get away with it I would have this motor!!! But...I can't so I can only wish!
IF IT'S WORTH HAVING, IT'S WORTH WAITING FOR!!!! (AND IT WAS)
434RWHP/403RWTQ Livernois Motorsports 2C Cam kit Kooks 1 7/8 LT Headers/Hi-Flo Cats/Corsa Exhaust Roto-Fab CAI / Port Intake Precission 2400/2800 Converter/3.73 AAM gears Livernois Motorsports Tune Best time: 11.97 @ 117 MPH |
#13 |
Dont H8 Me Cuz U Aint Me
Drives: 2016 SS Sedan, 2017 Explorer Sport Join Date: Feb 2010
whats the compression?
#14 |
its a low compression motor but im not really sure but you still can call chad at golen engines and ask him any thing you want coz the motor is there at the shop
