Old 03-22-2013, 05:25 PM   #1
amerimuscle
Drives: 2011 Camaro 1SS
combining mods
If one were to go through the process of installing aftermarket (3.91) gears on a bolt on L99 are there any other mods that would be suggested to incorporate while the rear is disassembled to avoid doing the same labor down the road for other mods? First question would be "well what are the future plans/goals for the car?" Frankly I'm not sure as of now.
Ideas???
amerimuscle is offline   Reply With Quote
Old 03-22-2013, 05:40 PM   #2
SGNL99
Drives: 2010 2SS/RS CGM
I have an LS3, so I can't say L99 specific, but while I was doing work to the rear end I put in all the suspension mods I wanted at the same time. Took a little more time and planning, but I only wanted to strip the rear end once. Good luck!
CAI Black Intake w/ Apex scoop & ww bottle kit; VMAX throttle body; Borla S-type Cat back exhaust; Skip shift eliminator; Elite Engineering catch can; MGW short throw shifter; Stainless Works LT Headers w/ Hi-Flow cats and one awesome JRE TUNE! BMR stage 2 suspension; 3.91 gears
SGNL99 is offline   Reply With Quote
Old 03-22-2013, 06:50 PM   #3
amerimuscle
exact reason why i asked, thanks. I did see (seconds after i posted) that theres a sticky thread that touched base on doing some diff bushings while the rear end was apart.
Old 03-22-2013, 07:09 PM   #4
SPCBA
Drives: pleather and Chiclets
get all those bushings out of there and replaced properly. after the rear and diff bushings are replaced there isnt a reason to drop the cradle again
SPCBA is offline   Reply With Quote
Old 03-22-2013, 07:27 PM   #5
amerimuscle
cool, thanks.
Old 03-23-2013, 08:04 AM   #6
hrpiii
AKA "Beefcake"
hrpiii's Avatar
Drives: 2023 ZL1 Sharkskin
what about Half shafts, maybe go with the 1LE parts?
