03-23-2013, 08:22 AM | #1 |
HotRod
Drives: 2010 Camaro 2SS M6 Black/IO Int. Join Date: Dec 2010
2004 Honda Accord Transmission problems
Hey everyone just looking for some input. My girlfriend owns an '04 Honda Accord V6 auto. The other day I was driving from my parents and the car was slipping and the tach was shooting up to 4-5000 rpm and surging. I pulled over and shut it off for a min started it back up and drove very easily to our house it worked ok.
The next morning I checked the trans fluid and it was dark grey/blackish. (I had the fluid changed this past summer) there is a whining sound when the car is running, Not any pulleys, it's coming from the tranny side.. Torque converter? Anyways The car has a delay when goin into gear and slips... My question is should I bother wasting 130$+ on another trans fluid flush? I know it's only a small amount compared to replacing the trans( which I can get a fully Rebuilt for 1850$, with 20 000kms warranty) also there were no codes, I checked with a code scanner. Any input is appreciated Thanks |
03-24-2013, 09:39 AM | #2 |
Drives: '86 Monte Carlo SS Join Date: Nov 2010
The whining is the pump trying to force fluid through a blocked orifice in the trans.
I think the transmission is done, don't bother with the flush. How many miles (km's) on the Accord? |
03-24-2013, 09:46 AM | #3 |
ITCRNRS
Drives: 2018 ZL1 1LE Join Date: Jun 2012
Or that sound is the front pump in the trans cavitating due to low fluid level I would check the fluid level first with the proper procedure in park or neutral what ever honda calls for worth a try
2018 ZL1 1LE Ordered 6/29/17 Built 11/6/17 Delivered 12/7/17, Summit White, PDR, NAV, https://www.youtube.com/c/tylerpotter
SOLD: 2014 Summit White 1LE 2SS/RS, Recaros, NPP, NAV, KONI Yellow's SOLD: 2012 Black 2LT/RS, Fully 1LE swapped, Brembo swap |
03-24-2013, 09:48 AM | #4 |
HotRod
Thanks, there is 259000 kms on it.. Thanks for the input I'm trying to convince the GF that its gonna be a waste of money flushing it again.
03-24-2013, 09:48 AM | #5 |
HotRod
Fluid level is fine, very dark though
03-24-2013, 09:59 AM | #6 |
ITCRNRS
Sell her the 2010 and buy you a new 1LE? Easy trans fix
03-24-2013, 10:01 AM | #7 |
03-24-2013, 10:51 AM | #8 |
HotRod
I wish I could lol
