Old 03-24-2013, 05:25 PM   #1
bannonm
bannonm's Avatar
Drives: 2011 2SS/RS M6 VR
CTS-V/ZL1 caliper on SS
Anyone who has done the conversion know if stainless brake lines for the SS will work with the CTS-V calipers? I already have Goodridge SS lines and hoping not to have to buy a complete set just to get the fronts.
bannonm is offline   Reply With Quote
Old 03-24-2013, 07:04 PM   #2
Synner
Drives: cars
They're going to be very tight depending on the brand. Test them lock to lock before putting the wheels back on. The Goodridge ones I got from JDP were a bit longer but I didn't measure to see by how much.
Old 03-24-2013, 07:13 PM   #3
Stealth 2010 2SS/RS
Stealth 2010 2SS/RS's Avatar
Drives: Black 2SS/RS M6
I think GM high tech did the swap for one of their articles and I think they reused the stock line but I think they had plans of replacing them.
2010 LS3 2SS/RS M6
AirAid Cold Air Intake, AAC LED sidemarkers, AAC P13w plasmas drl, Kook's Custom 1-7/8" Headers, Corsa Hybrid Exhaust
JRE 445 Cam Package, JRE SCT Tune, RX Catch Can and Breather
Tech AFX Heater Hose Relocation Kit, Black Chrome Wheels
Pfadt trailing and toe arms, Pfadt solid subframe mounts, Pfadt diff bushings, Street Slayer Twin Carbon
Technostalgia Camaro LED taillights, CTS-V Front Brakes, Powder Coated Calipers By ME
MGW Short Throw Shifter
Complete ZL1 Rearend Swap
Stealth 2010 2SS/RS is offline   Reply With Quote
Old 03-25-2013, 09:00 AM   #4
Bruce@raymondsperformance
Bruce@raymondsperformance's Avatar
Drives: 2014 Z28 camaro
They should work but make sure you check them with the wheels turned lock to lock and you should be fine.
Bruce@raymondsperformance is offline   Reply With Quote
