![]() Drives: 2010 Camaro 2SS/RS Join Date: Feb 2013
DIY interior paint?
If I was to paint my speedometer and steering wheel bezel,
What grit sandpaper would you use? And would you use an adhesion promoter or a primer? Then to finish it, would you spray it with a clear coat? I've painted a couple things myself but the paint doesn't seem to stick and chips easily. Any tips or tricks on how to keep the paint on? Thanks
2010 2SS/RS- every option possible in 2010
Lighting- LED footwell, grille, trunk, and engine lights done via DIY. LED dome, DRL, and tag lights. Paint- Painted engine cover, steering wheel bezel, speedometer bezel, front bowtie, tail light bezels, wheel center caps. Exterior lights- tinted tail lights and sidemarker lights. Wheels- powdercoated stock RS 20' wheels black Exhaust- Cat-back Dynomax Bullet Exhaust system with bullet muffler delete. Misc- rear blackout kit from Big Worm Graphix, black side Camaro lettering from Emblem Pros, and rear Camaro lettering from Emblem Pros. |
![]() Drives: 2012 Camaro LS Coupe Join Date: Dec 2012
If you want to use black or white as a color you could use plastidip and you don't have to put a base coat plus you can revert it back whenever.
How does the plastidip work ? I've heard about it but never really looked into it
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 CGM Camaro LS A6 Join Date: Jan 2011
You clean the part that you're going to spray and just spray the plasti dip. Don't sand. Spray a light first coat and heavy coats after and done. If you ever want to take it off, you just grab a piece and start pulling. If you did heavy coats at the beginning, it should all come off in one piece. Pretty easy to use.
Having said that, I wouldn't really use it in the interior though. Plasti dip has a rubbery feel to it that I don't know if I'd like in the interior. If you want that smooth feel, you're going to have to paint and clear the parts you're going to do. |
Oh ok. I appreciate that! I want to paint my engine cover too and I think plastidip might work for that. How close is it to the factory white ?
#6 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro LLT/RS Join Date: Apr 2012
If you paint the engine cover you need to make sure to use high heat paint. I don't know if plastidip can be used on an engine cover due to the high temperatures.
#7 |
I've never used the white so I wouldn't be able to tell you, but for engine cover I suggest you use spray paint instead.
#8 |
![]() Drives: 2010 2SSRS M6 Rally Yellow Join Date: Feb 2010
I painted my engine cover with regular Krylon paint and have not had any problems with the heat.
#9 |
Blowin the doors off!
Drives: A 2013 SS RS 6M SR Join Date: Apr 2010
+1 on the krylon paint. I have their red matches up to victory red really well and the "fusion" paint bonds to the plastic really well. I use up to 1200 grit and then put about 7 coats of thr krylon the 3-5 coats of clear. Usually turns out flawless.
2G1FS1EWXD9163847 |
#10 |
Smoked by a GIRL
Ive painted several things such as my interior and engine covers. Youll need 600-800 grit sandpaper,take the shine off of it. Wash with soap and water and alcohol. Ive used Rustolem with zero issues. Primer (2-3 coats) Paint (3 coats not thick not thin coats) Clear (3 coats the same) install no sooner then 24 hours. Be careful for a week, takes 5-7 days to fully adhere. Looks flawless. Get asked constantly who did my paint work at car shows.
Plastidip is a matte finish and ha.s a yellow tint compared to SW. I dont think it belongs on the interior. It can be used under the hood. Its rated for temps up to 200*, the engine cover does not get that hot. Same with regular paint, you dont need high temp paint. Heres some things Ive done. All the pink and white minus the door inserts I did myself last winter My latest project, my plenum cover yet installed Gloss black oil cap with reflective bowtie vinyl This was my other Camaro that I traded in. Thats all paint work, cgm with hot pink flames.
2014 2SS/RS Summit White w/ IOM interior "Powder 2.0"
#11 |
Drives: 2011 2SS/RS Join Date: Aug 2012
I wouldn't plasti dip anything. It comes off to easy. Put in the extra work and enjoy.
#12 |
Apologies to the OP not trying to thread jack, but I thought that these two (adhesion promoter and primer) were the same? What's the difference between the two?
The DREAM is free... It's the HUSTLE that is sold seperately
#13 |
Switchin' n Twitchin'
Drives: 2011 Camaro Join Date: Nov 2010
Adhesion promoter helps paint stick to plastic parts.
I am not childish, you're just being a poopy head!
| Tags |
| interior paint, painted interior, speedometer bezel, steering wheel bezel |
