Old 03-29-2013, 07:44 PM   #1
jeremywes
jeremywes's Avatar
Drives: 2012 Camaro SS
Rear cradle feel like it's about to fall off
A few days ago I noticed my car started making this side to side motion that feels like it coming from the rear. It does it at about 35+ mph. I check the alignment, tried different wheels and tires, went through every bolt including rear subframe bolts to check torque spec and cannot find anything loose or broken. Any ideas would be helpful.
Current mods include coil overs, sways and end links, pedders alignment kit, front bushing inserts and steering rack bushings but rear is otherwise stock.
jeremywes is offline   Reply With Quote
Old 03-29-2013, 07:46 PM   #2
The Stig
knows 2 facts about ducks
The Stig's Avatar
Did you time the bushings when you installed them?
Click to view my build thread
Old 03-29-2013, 08:10 PM   #3
jeremywes
jeremywes's Avatar
Yes, bushings were timed following the pedders procedure.
Old 03-29-2013, 10:17 PM   #4
JusticePete
Drives: Camaro Justice
If nothing is loose or bent, the most likely cause is the toe is out of spec. Get your Camaro on an alignment rack to check the toe.
Old 05-13-2013, 08:36 AM   #5
jeremywes
jeremywes's Avatar
Pete, you were spot on by the way. When I first inspected it I started by checking all the bolts that had been removed or replaced by my mods, they were all tight. The drivers side rear toe bolt that was loose was a factory bolt that at the time had never been touched.
Now they have all been replaced, thread locked and torqued. Problem solved.
Thanks
Old 05-16-2013, 12:45 PM   #6
JusticePete
Thanks
Even a broken clock gets it right twice a day
Old 05-16-2013, 12:50 PM   #7
The Stig
The Stig's Avatar
The man does know his suspension
