Old 03-30-2013, 07:19 AM   #1
Ajmalian
Ajmalian's Avatar
Drives: 2017 ZL1 and 2016 GMC Sierra Denali
Wobbly steering wheel between 50mph and 75mph
Hey guys...hope you can help me out with this...as the title above mentions...I have a steering wheel that vibrates/wobbles/even swings vigourously between 50mph and 75mph. Now generally this happens when your wheels aren't balanced. Funny thing is that I just got new wheels and tires a couple of days ago and all the necessary work (wheel balancing & alignment) was done after wheels and tires were installed. The car drove fine for two days...and its not even like I drove over anything odd....just good ol smooth tarmac...and this morning for some odd reason the wheel started wobbling between those speeds. I took it back to the tire guys, they checked and they said everything was fine...so why the steering is still shakin is yet a mystery to them too.
Any guesses why this is happening? Axle or something?
Ajmalian is offline   Reply With Quote
Old 03-30-2013, 08:50 AM   #2
Scott@Bjorn3D
Probably lost a weight. Sometimes they do not stick on and can come off.
Scott@Bjorn3D is offline   Reply With Quote
Old 03-30-2013, 09:21 AM   #3
2011ss/rs
2011ss/rs's Avatar
Drives: 11 ss/rs RJT w/Black Cherry stripes
Send a message via AIM to 2011ss/rs
Sounds like a belt broke in one of the new tires.
I just had the old wobbly,vibrating steering wheel thing happen to me and that was the cause, the tire finally blew apart and replaced it all good now....
2011ss/rs is offline   Reply With Quote
Old 03-30-2013, 09:21 AM   #4
crustychev
crustychev's Avatar
Drives: 2013 ZL1,1972 Dart, 1947 Willys
Move the front tires to back, back to the front. If it goes away it is a tire. I have got a new bum tire more than once in the past.
crustychev is offline   Reply With Quote
Old 03-30-2013, 01:48 PM   #5
SPCBA
Drives: pleather and Chiclets
properly rebalance the wheels. you could have a bad tire but i would think the balance is a muh higher probability to be the issue
SPCBA is offline   Reply With Quote
Old 03-30-2013, 02:55 PM   #6
JusticePete
Drives: Camaro Justice
Back to the tire shop for a road force balance to see if a tire is bad or a weight has been lost.
Old 03-30-2013, 06:37 PM   #7
Rob@WretchedMS
Drives: His Wife Crazy
If you have new wheels they may need to be re-torqued also, but you are likely looking at heading back to the store for a re-balance. Be sure that the wheels you have are either Hub Centric, or have Hub Rings installed in the wheels.
Rob@WretchedMS is offline   Reply With Quote
Old 03-31-2013, 04:51 AM   #8
Ajmalian
Ajmalian's Avatar
Thanks for your feedback guys...will certainly look into it ASAP!!
I doubt its rebalancing....however I need to look into the hub-centric issue....there maybe a possibility that the rings may not have been installed now that I think about it!
Once again, thanks!
