![]() Drives: 2013 AGM 2SS/RS LS3 Join Date: Mar 2013
Remove dual-mode exhaust
Based on all the research I have done I have not seen where anyone has removed the stock dual mode mufflers and replace them with flowmasters or something. Anyone done this and/or have suggestions? Also I noticed a lot of people mention the vibrating or clunking or rattling problem with camaro exhaust, I'm pretty sure this is going on with mine, anyone else have this issue with 2013 ss dual mode exhaust? Another assumption I have after researching is that solo performance cats will not void warranty, is this accurate and would replacing the dual mode mufflers with flowmasters outlaw axle back kit void warranty? And will my air raid cai void the warranty? Several questions in their, thanks for any help yall can give me.
This is what knocking I am referring to:
http://www.camaro5.com/forums/showth...ghlight=PI0027 |
![]() ![]() Drives: 2016 2SS coupe 2015 3LT Stingray Join Date: Aug 2012
The items you replace will not be warrantd but as a whole your warranty wont get voided withs hiflow cats headers intakes or exhaust however if or once you tune you will void the powertrain warranty
Ported intake manifold and throttle body kooks 2" headers no cats
Yes I was tracking on the tuning, thats why my bullydog programmer is going to be sold and will not be going in the camaro, thank you for the info on the exhaust and intake though.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2015 Z/28 #533 Join Date: Jul 2012
I'll buy the mufflers off of you
#6 |
I will keep that in mind if I do replace them, every flowmaster kit says it does not fit if car has dual mode exhaust.
#7 |
#8 |
Not sure, flowmasters cat back kits also say they don't fit if car is equipped with dual mode exhaust, im gonna have to email solo performance and see if their mach x kit will work.
2013 AGM 2SS/RS LS3
Flat Black Rally Stripes Dual Mode Exhaust w/ fuse pulled Air Raid CAI Solo Performance Highflow Cats Tinted windows and tail lights Aqua Blue LED dome light, trunk light, footwell lighting Black powder coated billet front & rear bowties |
#9 |
#10 |
and if you do go catback you might as well do long tubes
#11 |
I would keep the dual mode and get headers instead.
The dual mode is awesome. |
#12 | |
Bayou City Muscle Cars
Drives: 2013 2SS Dusk Edition Join Date: Jan 2013
sounds better than nearly every other cat back we have put it next to. has a very very mean but refined sound with the fuse out. with the fuse in it becomes a kitten that purrs unless you flatten the throttle. I would never switch them out with anything especially now that my car is cammed and has headers and cats. with the fuse pulled it is thunder but with it in I can sneak though neighborhoods without drawing the attention of the cops. There are no issues with the DM itself. most rattles have turned out to be other things. my rattle was just a loose piece of weld that broke off inside the muffler and got trapped. since then no issues at all.
Lethal Racing Stage V PER 418ci Forged LS3 530/520 SAE |
#13 | |
completely unrelated.
#14 |
Im not sure what yall are hearing but I respect your opinions. I had true duals in my 2004 silverado 5.3L using two flowmaster super 44's and it made my 2013 camaro ss dual mode with fuse pulled sound like a kitten. It was a very deep rumbling exhaust that shook the walls in the garage and woke the neighbors. The stock dual mode even with fuse pulled is nothing compared to the cars I hear driving around. Now I will keep you posted on whether my opinion changes or not after I install the CAI and solo performance high flow cats. Maybe I will end up keeping the dual mode mufflers, but my current opinion is that flowmasters sound way better as well as some other mufflers I have heard on these cars. Just my opinion.
2013 AGM 2SS/RS LS3
| Tags |
| airraid, flowmaster exhaust, solo performance |
