![]() ![]() ![]() ![]() ![]() Drives: 2012 SIM 2LT/1970 Camaro Join Date: Nov 2012
Data to Show Effects of Carbon Build Up?
So, I've been playing around with the Torque app, collecting data from my daily drives back and forth to work. I've started to put the data into Excel spreadsheets, and want to do some graphs of various data points that could show the effects of the carbon build up our DI engines (with no catch can) are subject to.
My car has ~26,000 miles on it with no can, and I'm sure it's got some good sludge on those valves. My plan is to collect some baseline data running 87 octane fuel (done), then some running 93 octane (still to come), then I will investigate/clean the upper induction (and hopefully install a catchcan, if $$$ allows) and repeat the data collection. But I need to ask those who have greater knowledge than me (ie, everyone), what data points will show a difference? I can collect data on fuel trims, knock retard, timing advance, AFR, and more. Which ones would most demonstrate the effects of the carbon build up? Ideas? I need to narrow the list for graphing purposes, to make it usable. EDIT: See post #70 for my initial data sets/graphs. Last edited by 911medic; 04-17-2013 at 04:38 PM. |
Drives: 2012 Camaro RS, RX supercharged Join Date: Dec 2009
I am not sure any looging data would show up as it is reducing the CFM of flow (that would be a physical flow bench test) and the volumetric efficiancy of the port and valve tulip design that is changed.
MAP sensor data on the LFX may show a variance, so may show something there. the LLT has no MAP so that dosent help. I like this thread though. Here is another compilation of pictures dealing with the issue on all makes of DI engine: http://isearch.avg.com/images?s=side...snd=hp&pid=avg |
#3 | |
![]() Drives: 2013 Camaro 2LT Join Date: Mar 2013
Drives: 2011 Camaro LS Join Date: Dec 2010
It doesn't need a can but if you can afford it your an idiot if you don't install one.
#6 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2012 LS M6, Black Join Date: May 2009
John B.
1995 Mitsubishi Montero SR 1987 Dodge Raider Turbo Project 1986 Mitsubishi Montero 2.4l FI Transplant |
#7 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: ( . )( . ) Join Date: Feb 2010
![]() Do you know how Direct Injection works?
#8 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 11 F150 EB/13 Sonic RS/15 Z06 Join Date: Sep 2010
Why would a Port Injected engine need one but not a Direct Injected engine?
New Ride -- 2015 Z06 2LZ (stock) -- Journal
Old Ride -- 2012 Camaro 2LT/RS (647 RWHP & 726 RWTQ) -- Build Thread |
#9 | |
#10 |
LOL!!!! Has to be!
#11 |
Except he made a similar comment two days ago.
http://www.camaro5.com/forums/showth...87#post6360487
#12 |
![]() ![]() ![]() ![]() ![]() Drives: '12 2LT Convertible Join Date: Mar 2012
Yesterday I witnessed firsthand the need for a catch can while cleaning the intake manifold of my LFX. Tremendous oil and carbon buildup after 14K miles without one.
Mods: GM Locking Gas Cap, RS License Plate Frame, SS Brembos, ZL1 FrontEnd, 14/15 Convertible Top
#13 | |
31.5 years as GM engineer. You believe all the "snake oil" distributors on the auto scene??? You guys are a riot. You need to use detergent gas and you engine will be just fine. No catch cans! If these were necessary they would be on your cars from the factory!!!
#14 | |
