Old 04-01-2013, 09:13 PM   #1
Birm
Birm's Avatar
Drives: Florida Speed & Power
SS Fuel Pump
I took it out when I did my SC, just sitting around.
75 Shipped. Nothing wrong with it, just needed a bigger one to maximize the SC
Birm is offline   Reply With Quote
Old 04-02-2013, 09:44 PM   #2
Birm
Birm's Avatar
TTT
Old 04-02-2013, 11:32 PM   #3
Chris82xx
Make your peace with God!
Chris82xx's Avatar
Drives: 2011 Camaro SS/RS M6 Convertible
Contact Andy over at Squash. I think they might be buying them at $50 a pop. It's not what you're asking for but at least it's something. I'm just not 100% sure about it. Doesn't hurt to check it out.
ECS base supercharger (NOVI 1500SL), ECS AlKY control kit, 92mm TB, ARH 1 7/8" LT's non-catted, Borla 3" exhaust, ID850 injectors, Squash fuel system, ECS Big Blower Cam, MGW short throw shifter, DSS 1000hp axles, LGW differential cover, billet caps, Tech AFX heater hoses, Pedders differential bushings, Eaton TrueTrac differential, PRC dual valve springs, Katech C5R timing chain, ATI balancer, Meilings oil pump, Pfadt Trailing Arms, Pfadt Tie Rods, Pfadt Sway Bars, Pfadt End Links, DSS Aluminum Driveshaft
811RWHP/719RWTQ
UNDER MAJOR OVERHAUL!!
Chris82xx is offline   Reply With Quote
Old 04-03-2013, 02:12 PM   #4
Birm
Birm's Avatar
thanks bro will do.
