Old 04-05-2013, 02:31 PM   #1
CamaroDIYking
Drives: 2010 Camaro 2SS/RS
Painted door handles
Any clue on how to take the chrome door handles off to be painted ? I don't have any chrome on the car and they annoy me. Do I have to take the whole door panel off or can I do it just from the inside ?
2010 2SS/RS- every option possible in 2010
Lighting- LED footwell, grille, trunk, and engine lights done via DIY. LED dome, DRL, and tag lights.
Paint- Painted engine cover, steering wheel bezel, speedometer bezel, front bowtie, tail light bezels, wheel center caps.
Exterior lights- tinted tail lights and sidemarker lights.
Wheels- powdercoated stock RS 20' wheels black
Exhaust- Cat-back Dynomax Bullet Exhaust system with bullet muffler delete.
Misc- rear blackout kit from Big Worm Graphix, black side Camaro lettering from Emblem Pros, and rear Camaro lettering from Emblem Pros.
CamaroDIYking is offline   Reply With Quote
Old 04-05-2013, 02:54 PM   #2
StephenS_84
Drives: 2011 2SS/RS
I'm not sure how they come off exactly, but I'm pretty sure the door panel does have to come off. Once you take it off I'm sure you will see how the handles come off. This is a project for me as well.
StephenS_84 is offline   Reply With Quote
Old 04-05-2013, 02:55 PM   #3
Asian Zero
Asian Zero's Avatar
Drives: 2010 IBM Camaro 1LT RS
It would probably be easier if you took off the door panel. Its not that bad only a couple of bolts and screws. hardest part is disconnecting the wiring from all the switches.
Asian Zero is offline   Reply With Quote
Old 04-05-2013, 05:53 PM   #4
Badman24
Badman24's Avatar
Drives: 2SS Black W/GFX
Actually you don't need to pull the door panel off. It's one screw in the door jam behind a round plastic cover. Just pull the handle open as you loosen the screw, after a few turns you can let go and the handle will not close back. Keep turning the screw until you can pull out the lock cylinder and then the handle itself. I will find a video to show you.
Badman24 is offline   Reply With Quote
Old 04-05-2013, 05:56 PM   #5
Badman24
Badman24's Avatar
Here you go. http://m.youtube.com/#/watch?v=UMHv0sg1ByY&desktop_uri=%2Fwatch%3Fv%3DUMH v0sg1ByY
Old 04-05-2013, 06:00 PM   #6
Badman24
Badman24's Avatar
Tried to post a link, sorry I couldn't get it to work
Old 04-05-2013, 06:57 PM   #7
FL1CK
Switchin' n Twitchin'
FL1CK's Avatar
Drives: 2011 Camaro
Once you have the door panel off the handles are melt welded on the back... you can tape them off in the door and paint. That's what I'm doing this weekend among other things.
I am not childish, you're just being a poopy head!
FL1CK is offline   Reply With Quote
Old 04-05-2013, 06:57 PM   #8
FL1CK
FL1CK's Avatar
Drives: 2011 Camaro
That's for the outside, those aren't chrome. He's talking about the inside.
Old 04-05-2013, 07:01 PM   #9
FL1CK
FL1CK's Avatar
Drives: 2011 Camaro
pic
Here's a pic of the back so you can see the melt welds
Old 04-05-2013, 09:32 PM   #10
FL1CK
FL1CK's Avatar
Drives: 2011 Camaro
Got mine taped off, waiting for tomorrow to get them painted. I'm plasti-dipping mine, and may flat clear them as well.
Old 04-06-2013, 12:59 PM   #11
CamaroDIYking
Yes I'm talking about the inside
Old 04-06-2013, 01:36 PM   #12
StephenS_84
Drives: 2011 2SS/RS
Old 04-06-2013, 01:37 PM   #13
StephenS_84
Drives: 2011 2SS/RS
Sooooo could these be swapped out for new ones?
Old 04-06-2013, 03:21 PM   #14
FL1CK
FL1CK's Avatar
Drives: 2011 Camaro
pics
Cut the welds and pulled them out
diy paint, door handles, interior customization
