Old 04-06-2013, 10:51 AM   #1
ZL1-V
Drives: 2013 Camaro ZL1
ZL1 rotor swap
I had this done a few days ago swapping out my factory rotors for a set of Racing Brake rotors. Lighter discs and the brake pedal response feels a bit more progressive. I can modulate them better when stopping without activating the ABS as much. They are installed correctly the RB disc all have the slotted/ cross drilled holes facing forward but allow the curved vane on the inside of the disc is as designed to sweep rearward for proper cooling. They were granted a patent for it's design.
ZL1-V is offline   Reply With Quote
Old 04-06-2013, 01:10 PM   #2
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
The Racing Brake 2 piece open slot rotors perform very well and help you shed a nice chunk of rotating unsprung mass. Plus they look cool!
Old 04-06-2013, 02:37 PM   #3
JusticePete
Drives: Camaro Justice
Are the RBs lighter than the ZL1 front or is it the rears that are lighter or both?
Old 04-06-2013, 02:43 PM   #4
Sapper12b
HTCC Member
Sapper12b's Avatar
Drives: 2013 Camaro SS
Same question ...
Sapper12b is offline   Reply With Quote
Old 04-06-2013, 03:34 PM   #5
cvp33
America FVCK Yeah!
cvp33's Avatar
Drives: 2024 Z06
Awesome. Where and how much?
cvp33 is offline   Reply With Quote
Old 04-06-2013, 03:52 PM   #6
Apex Motorsports
Originally Posted by Sapper12b View Post
Same question ...
The front and rear rotors are both lighter than stock. On the ZL1 the fronts are 2 lbs lighter each and the rears are 6 lbs lighter each. On the SS the fronts are 5.5 lbs lighter and rears are 6 lbs lighter.
Vendors are not allowed to post pricing in the technical forums but hit us up and we can get you squared away. PM sent.
Old 04-06-2013, 04:10 PM   #7
Sapper12b
HTCC Member
Sapper12b's Avatar
Wow ... That's a lot of weight for just being rotors. Something definitely on my list of MOD's to do. Now my next question. What other brake rotor manufacture, besides Racing Brake, have such a weight saving rotor ?
Old 04-06-2013, 04:12 PM   #8
Apex Motorsports
It is indeed. None that I am aware of. To lose that kind of weight takes a 2 piece rotor and some good engineers.
Old 04-06-2013, 05:07 PM   #9
The Stig
knows 2 facts about ducks
The Stig's Avatar
None, and to be honest - no other brand of rotor even comes remotely close to the weight savings you get from Racing Brake.
Click to view my build thread
Old 04-06-2013, 06:20 PM   #10
JusticePete
It makes sense that the rears would be much lighter. The OE has an iron hat and the RB has an aluminum hat. Up front the only way to take weight out is to have less material in the ring as there won't be much difference in the weight of the hats.
