Old 04-09-2013, 07:53 AM   #1
IneedAZ
IneedAZ's Avatar
Drives: 2017 ZL1 A10 & 2021 BMW M340i x Dr
Any V6 guys done a gear swap?
What did you go with? Glad you did it? How did you calibrate your speedo?
Thinking of changing to a 3.7 gear if available to get the car into the rpm band quicker. Lot of weight to get moving. Thoughts?
Sold 2012 2LT RS 12.3@112 old setup
Sold 1967 Camaro Pro Street. Ran 10's mild BB on NOS.
2017 HyperBlue ZL1 A10 ** Born 3/17/17**Delivered 4/08/17
2020 Build: Mag2650, BTR Stage2, NW103, BG, 14% lower, 90mm upper, ARH 2" Long system w/no cats, SW Legend mufflers. **807hp/762tq on 93 gas** and **848hp/792tq on e47**
Sold 2018 (Go Mango) Dodge Charger Daytona 392 Daily Driver
Daily Driver 2021 BMW M340i Xdrive
IneedAZ is offline   Reply With Quote
Old 04-09-2013, 10:58 AM   #2
JohnnyBfromPeoria
JohnnyBfromPeoria's Avatar
Drives: 2012 LS M6, Black
Are you M6 or A6? If M6, I'd go straight to the 3.91's. It's a drop-in.
John B.
12 LS M6, IPF S/C, ASA GT-5 wheels, VMax PTB
1995 Mitsubishi Montero SR
1987 Dodge Raider Turbo Project
1986 Mitsubishi Montero 2.4l FI Transplant
JohnnyBfromPeoria is offline   Reply With Quote
Old 04-09-2013, 11:40 AM   #3
wwoody
wwoody
Drives: 2011 Vert
After reading different threads/posts on rear end gear swaps I bought the 3.91's for my LLT. People that had prevously changed gear sets commented that they thought the rear end gear swaps was the best mod for the money, and car felt lighter. You're going to go through the gears a little faster and fuel. (and possibly tires if you like to drive like me. )
I will be getting mine installed next week. Can’t wait.
wwoody is offline   Reply With Quote
Old 04-09-2013, 11:43 AM   #4
IneedAZ
IneedAZ's Avatar
Mine is an automatic. What is done about the speedometer? How is it calibrated?
Old 04-09-2013, 07:10 PM   #5
etmx183
etmx183's Avatar
Drives: 2012 Camaro 2LT RS
Automatic with a V6 (2012/2013 not sure about previous years) requires a complete diff swap to use anything except 3.55. That is the only gear I am aware of that will fit this POS diff they gave us V6 automatics and it can not be turned into a posi yet either. You will need a center section from a manual V6 or any SS, both axles, both wheel hubs and the rear section of a driveshaft to make your front driveshaft section to a rear section to bolt up to the new diff center section. Than you can have a world of gear to pick from. I tell you this from experience, I did the complete swap a few weeks ago. I only went with 3:42 gearing ( that came in the rear ) I needed the posi-traction to help me hook up when I use nitrous. Trifecta sent me an update for the speedo fix. I would order some diff bushings while you do the swap and maybe some other rear suspension upgrades, bushings, arms, and other goodies while it is out for the swap and save some labor while it is apart. I know there are vendors on here that keep all that stuff in stock and ready to sell.
etmx183 is offline   Reply With Quote
Old 04-09-2013, 07:29 PM   #6
IneedAZ
IneedAZ's Avatar
Did u notice much just going to the 3.42 it came with without the nos vs the stock? Isn't stock 3.29?
Old 04-09-2013, 08:01 PM   #7
hawkfe
Drives: 2014 Stingray 3LT
I did the diff swap to 3.91s and love them. Does make the car feel lighter (more responsive), now getting use to the new rpms to gears. Trifecta sent me an update to my tune for the speedo fix.
hawkfe is offline   Reply With Quote
Old 04-09-2013, 08:57 PM   #8
IneedAZ
IneedAZ's Avatar
I was thinking a 3.7 gear at most. I drive too far for work to go 3.91. That's why I didn't buy the SS.
Old 04-09-2013, 10:49 PM   #9
etmx183
etmx183's Avatar
I have not been to the track yet to verify with & with nitrous yet. I also did the SOLO HFCs and BMR bushings for the diff, cradle, upper and lower arms all at the same time with the diff swap. I'm hoping to get some track time in the next two weeks. I can say the car leaves firmer and quicker on motor than before. My G-Tech Pro is showing about 1.5 tenths quicker for the 1/4 stats and about 3.5 MPH more than before all the mods listed above. Gas mileage has not changed when I drive normal on a long trip at 60 -65 mph. I still get around 26.5 -27MPG, I always run premium fuel also. I know octane is for knock not MPG but I know I run it hard and had the tune set for premium fuel.
QUOTE=IneedAZ;6404177]Did u notice much just going to the 3.42 it came with without the nos vs the stock? Isn't stock 3.29?[/QUOTE]
Old 04-11-2013, 08:31 AM   #10
IneedAZ
IneedAZ's Avatar
Originally Posted by SC2150 View Post
Your close. We do the complete diff swap with axles, driveshaft, hubs, and gear of your choice plus adjust the speedo in the tune.
Let me know if you want it done right.
I see it says account suspended...PM me with price do to this when u are able. This might be price prohibited...Im sure its alot more then a simple gear swap that i am looking for. Let me know!
Old 04-16-2013, 08:40 AM   #11
IneedAZ
IneedAZ's Avatar
Anybody do the 3.55 gears so you didnt have to do the rear end swap? Did it make enough difference from the stock?
Old 08-12-2013, 06:34 PM   #12
One Sick Camaro
That Cam though...
One Sick Camaro's Avatar
Drives: 11 Camaro 2SS 02 T/A WS6 15 SSV
i'm torn on what gears to put in my auto too. buying a whole ss rear but gear wise idk lol
One Sick Camaro is offline   Reply With Quote
Old 08-12-2013, 08:06 PM   #13
IneedAZ
IneedAZ's Avatar
I went with the 3.7. Being that the Auto has such a steep first gear, I was afraid that I wouldn't make much use of first before it shifting into second. Plus I was afraid at the track I would have to shift into yet another gear on the top end which could potentially slow me down a hair.
Old 08-13-2013, 05:02 PM   #14
One Sick Camaro
That Cam though...
i'm thinking 3.73's was gonna do 3.91's but feel it ma be a little too much
