Old 04-09-2013, 02:07 PM   #1
rforbes
rforbes's Avatar
Drives: IOM SS/RS
Cats
So I have read quite a few posts about high flow cats melting and coming apart after about 25K miles or so. I had my car in the shop for some other work, so I had them inspect the cats. Sure enough they were coming apart and I was about to have a complete blockage at any time. The shop did not have any x-pipes for my setup so I had them just gut the cats until I can have it fixed. So, why put on high flow cats if they are just going to fall apart?
rforbes is offline   Reply With Quote
Old 04-09-2013, 02:22 PM   #2
Cruuzin LV
Cruuzin LV's Avatar
Drives: 2012 Camaro SS 45th Anniversary
Are you running LT's and high flow cats or just shortys/stock with the Solo or JBA setup?
Cruuzin LV is offline   Reply With Quote
Old 04-09-2013, 02:26 PM   #3
SPCBA
Drives: pleather and Chiclets
who ever told you cats last for ever lied to you. your setup should have an x pipe regardless of cats...just keep the gutted cats and add a true x pipe
SPCBA is offline   Reply With Quote
Old 04-09-2013, 02:31 PM   #4
rforbes
rforbes's Avatar
Drives: IOM SS/RS
Long tube headers with the high flow cats.
Old 04-09-2013, 02:34 PM   #5
rforbes
rforbes's Avatar
Drives: IOM SS/RS
I expected them to last longer than 20K miles. lol
Oh well, I should get better performance now.
Old 04-09-2013, 02:55 PM   #6
Kelly@PCMofNC
Drives: 2010 RS/SS
They don't last forever but I would be surprised to see them come apart after only 20k. What brand?
Kelly@PCMofNC is offline   Reply With Quote
Old 04-09-2013, 02:57 PM   #7
rforbes
rforbes's Avatar
Drives: IOM SS/RS
Not sure to be honest Kelly. Another shop put them on when they put on the American Racing headers. Guess I was going to be blowing pieces out the tail pipes soon so I am glad I had them checked out.
Old 04-09-2013, 04:13 PM   #8
RJT-SS
RJT-SS's Avatar
Drives: '11 2SS/RS A6
Anyone know a reasonable number of miles that these high-flow cats should last? I am referring to the better known brands (Solo, JBA, Dynatech, SW, Kooks, etc.).
Performance Mods:
Kooks 1-7/8 LTs; Calico coated w/HFCs, Solo Mach XL catback w/J-pipes, VMax TB, C.A.I. Intake, JRE Tune, RX Catch-Can
RJT-SS is offline   Reply With Quote
Old 04-09-2013, 05:44 PM   #9
Mchlgrrsn
Stroked and blown
Mchlgrrsn's Avatar
Drives: 2010 LS3 2SS
All cats come apart under boost. Quickly. If you don't have boost I would think they should of lasted longer than 25k. Anyway I don't see any good reason to run high flow cats. Leave the gutted ones on, they will never fail you now.
Mchlgrrsn is offline   Reply With Quote
Old 04-09-2013, 08:52 PM   #10
Rick@MidwayPerformance
Drives: 2010 & 2012 Camaro SS
Not true!!! I have 61k on a set of high flow cats from Dynatech, boosted @ 11lbs, cammed, meth, etc, you get the jist, no issues with my cats. Its all in the tune, if its not perfect they will come apart. And to those that are wondering, this car has over 40 track days, most have been road course, about 6 drag and 3 or 4 auto-x, cats are still good.
Aftermarket high flow cats wont last forever but if your car is properly tuned they will live for a long time.
We have been installing and selling Dynatech's and Kooks with no issues for years, then again we have tuned most of the cars, either if we installed or the customer installed.
Rick@MidwayPerformance is offline   Reply With Quote
Old 04-09-2013, 09:24 PM   #11
right to travel
Drives: 2013 Camaro 1SS 1LE SW
what about high flow cats with the stock headers and tune?
right to travel is offline   Reply With Quote
Old 04-10-2013, 08:43 AM   #12
rforbes
rforbes's Avatar
Drives: IOM SS/RS
I do have a Maggie running 11 lbs of boost and I race quite a bit so I am sure that contributed quite a bit.
Old 04-10-2013, 09:49 AM   #13
caper
Drives: 2010 IOM 2ss/RS
it didn't contribute - it was the CAUSE...its widely known, FI? - no cats.
caper is offline   Reply With Quote
Old 04-10-2013, 10:14 AM   #14
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
There's even a thread dedicated to it in the FI section.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
