Old 04-11-2013, 12:43 PM   #1
rdblan2
Drives: 2SS RS
do I have an alignment issue or is this normal? now w/ alignment sheet
I just pulled my stock tires and wheels off the car to replace them. The stock rears didn't seem to like the whipple.
see alignment sheet further down the page.
You can see how both the rears are wore. Both of them were slick on the inside edge. The outsides were close to bald but as you can see not as bad. Since I just put the new 315 Nittos on, I wanted to make sure I don't wear them the same way.
I'm not lowered, and have BMR's rear suspension parts, sway bars, end links, trailing arms, lower control arms, bushings, cradle bushings etc.
Is this just because the car is squatting under the power of the whipple or should I go in for an alignment soon?
Nevermind all the crap in my shed!
Uploaded with ImageShack.us
Livernois 2C cam and tune, LS3 conversion, Roto-Fab intake, Kooks headers, DSS driveshaft and axles, BMR suspension parts, VMax ported throttle body, Whipple blower. (623hp).
rdblan2 is offline   Reply With Quote
Old 04-11-2013, 12:46 PM   #2
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
Probably a little of both.
Old 04-11-2013, 12:50 PM   #3
Trentin24
Trentin24
Trentin24's Avatar
Drives: 2011 2SS/RS
Did you align after all the suspension upgrades?
Trentin24 is offline   Reply With Quote
Old 04-11-2013, 12:52 PM   #4
PAUL SS
The Mark of Excellence
PAUL SS's Avatar
Drives: 2010 ABM 1SS RS LS3
If you changed suspension parts you need an alignment!
Old 04-11-2013, 12:52 PM   #5
rdblan2
Drives: 2SS RS
Yes, I had Tim at T&T Performance do the suspension install and he had it aligned after that was done. Didn't drive the car long before I added the whipple.
Old 04-11-2013, 12:56 PM   #6
Trentin24
Trentin24
Trentin24's Avatar
Drives: 2011 2SS/RS
Maybe it's the way he aligned it? Some do toe in/out. I've never seen rear tires worn that way. Sometimes fronts. Maybe take it to les Schwab?
Old 04-11-2013, 12:59 PM   #7
rdblan2
Drives: 2SS RS
I probably have the alignment sheet somewhere. Let me dig that up and I'll post it if I can find it.
Edit, I thought it was in the car but it doesn't appear to be there.
Old 04-11-2013, 01:01 PM   #8
Unknown SSRS
Drives: 2011 VR SS/RS
Your camber is off..
Unknown SSRS is offline   Reply With Quote
Old 04-11-2013, 01:37 PM   #9
Caswell239
Caswell239's Avatar
Drives: 2011 2ss/rs
too much negative camber. snap that pic with your phone and show the alignment shop was it was doing.
Caswell239 is offline   Reply With Quote
Old 04-11-2013, 02:31 PM   #10
jeremywes
jeremywes's Avatar
Drives: 2012 Camaro SS
I bet your camber was -1.5 or so . Drives good but it will wear that inside edge. especially if you are heavy on the skinny pedal
jeremywes is offline   Reply With Quote
Old 04-11-2013, 03:18 PM   #11
BMR Sales
BMR Sales's Avatar
Drives: Race Car
Like everyone else said it looks like you had a little too much negative camber. Post up the alignment sheet so we can see what your alignment specs are.
Old 04-11-2013, 10:32 PM   #12
rdblan2
Drives: 2SS RS
I'll take the car in for an alignment one morning next week and see what the deal is. Thanks folks!
Old 04-11-2013, 11:53 PM   #13
grocerygetter
instigator
grocerygetter's Avatar
Drives: 2020 6.2 Trail Boss, 2022 XC90
it'll handle good like that though. My most curvy road fun alignment was a -2deg front and -1deg rear with some toe out on the front...pfadt specs tweaked a bit.
I have the pedders street specs on it now...its good for tire wear but not near as fun. I'm more trying to get it to hook drag racing now though so trying to square up the rear is even more so importante.
-John S.
Old 04-12-2013, 09:00 AM   #14
jeremywes
jeremywes's Avatar
You might try a drag specific alignment spec. some positive camber will put your rear tire flat when your car squats on launch and increase your rear contact patch.
