I Done Caught Diabeetus.
Drives: 1972 Chevelle SS/2010 Tundra Join Date: May 2009
Running foglights and halos simultaneously?
Judging from the pics I've seen, is it safe to assume that you can't run the fogs and headlights simultaneously?
Anyone disappointed?
CANCELLED ORDER: 1SS/CGM/MN6/BLACK RALLY STRIPES |
![]() Drives: SS for Super Sexy! Join Date: May 2009
i am VERY disapointed in this ... because i would like that option .. however, running the halos at night does give the car quite a mean look as it has like glowing cat eyes kinda .... but i still want the option to run both at the same time
- Life is to short to let it pass you by
Supercharged
:bangdesk::bangdesk:
Camaro & Stang Enthusiast
Drives: 2011 Mustang 5.0 in Kona Blue Join Date: Mar 2008
yes, this is why I did not order the RS with the SS since I can't justify paying that much for headlights..
Bought my Camaro from Eric Hall(817) 421-7266
OH CANADA!
Drives: 2011 RAM 1500 LARAMIE Join Date: Mar 2009
WHAT?! YOU CANT RUN THEM BOTH AT THE SAME TIME! WELL THEN, I AM JUST GOING TO HAVE TO CANCEL MY ORDER!!!!!!
Had to trade in the Camaro for a truck :(, but hopefully I can join the Camaro family again one day ![]() |
#6 |
![]() ![]() Drives: 2012 CRT ZL1 #1400 Join Date: Apr 2009
HHHHmmmm! I am wondering now when I add the Halo's to my SS.... wire it to the Fog light switch..... cool!
#7 |
HOOK'EM
Drives: 97 c1500/92 olds Join Date: Oct 2008
#8 |
2010 Maro owner
Drives: 2006 Chevy Truck Join Date: Apr 2008
Give it time, there will be a aftermarket deal you can buy that will allow this.
#9 | |
HOOK'EM
just kidding all you need is a switch from your local autozone/oriley's or hell i think walmart has them and couple feet of wire with splice connectors. then just look at the headlight switch figure out which is ground, and power for the fogs(DRL) splice in and your done after you mount the switch and of coarse tuck everything back to make a nice clean install |
#10 |
Comic Curmudgeon
Drives: 2010 Camaro 2SS-2010 VW CC Sport Join Date: Mar 2008
![]() ![]() ![]() ![]() This has been posted on here about a dozen times sincethe car hit the streets. It is clearly stated inthe owners manual that the "Foglights" are DRL's not Foglights. THe HID's will give you plenty of light at night. I am sure you and many others will rewire your DRL's on a separate circuit so you can switch them on and off as you wish.
Member Illinois Camaro Club
His Name is Rosie - "Speak Softly and Carry a Big Stick!" - If you know who said that, then you know the genesis of his name. |
#11 |
![]() ![]() ![]() Drives: Camaro... soon Join Date: Aug 2008
so halos cannot be run with the fogs.... can the regular halogen headlights be run at the same time as the fogs?
2011 IOM or CGM 1SS
#12 | |
#13 |
another con for the RS, at least for me. thanks Supermans
2011 IOM or CGM 1SS
#14 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2SS/RS Join Date: Sep 2008
Why would you want to run the "fog lights" the same time as the HID's? The HID's give out far more light then the halogen lights in the "fog lights" so the "fog lights" will not improve your visibility at all. It would be like pointing both a key chain flashlight and commerical grade spotlight in the same direction and thinking that the key chain helps you see.
If you wanted to do it for looks, the factory "fog lights" would look silly with the HID's so you would have to change them to HID as well. This would be extremely blinding to other drivers and in some areas if your headlights blind a driver and it causes an accident, YOU are listed as being at fault. |
