Old 04-12-2013, 09:13 PM   #1
Rhyder
Drives: 2012 45 Anniversary Vert
Pedders rear Sway Bar
just looking for some info from others that have it.
I received the rear sway bar, pictured below, as part of a package. The shop installing it says it doesn't fit, its to wide/long. Its wide enough to almost brush the wheels on each side. It measures about 53-54" from tip to tip.
The shop compared it to one of theirs and it was longer than theirs.
They were wondering if it was one for another car maybe.
I ordered the kit for 2012 SS vert. I'm wondering if they sent me one made for another Camaro, maybe older or V6 or something.
I will be contacting Pedders Monday, and this is in no way a trash thread, just wanting to see if I can identify what this is for exactly so I can tell them correctly what I have.
Rhyder is offline   Reply With Quote
Old 04-12-2013, 09:42 PM   #2
R8E1D
R8E1D's Avatar
Drives: 2013 Ram 1500
I'd say its on the money. I measured from where the drop link bolt comes thru the control arm and I got about 56". Couldn't get a measurement on the top cause its on the car already. Hope this helps.
R8E1D is offline   Reply With Quote
Old 04-12-2013, 09:50 PM   #3
Avalnch
Avalnch's Avatar
Drives: Rally Yellow Camaro+Avalanche
That's the ZL1 sway bar for the FE4/FE5 suspension. Not sure what the 2012 Verts come with.
Vengeance Kaotik Cam, C.A.I., ARH LT, Pypes Cat Back, ZL1 Shifter+2012LS3VERT bushing, Quantum Brake Ducts, JDP Tow Hook Scorch Yellow Trim Kit, Shark Fin, AAC DRLs+ABLs+SMDs, ZTA Rear Spoiler, R.Y. 1LE Splitter. Pfadt coilovers, camber plates, trailing arms, Pegasus Solid Subframe. Pedders ZL1 barz, radius arm & steering rack bushings. BMR adjustable toe-rods. Hotchkis Max Chassis Brace. ZL1 GMPP Driveline Upgrade. TurnOne P/S pump. CTS-V 6 pistons.
447 HP @ 6180 RPM / 418 TQ @ 5100 RPM
Avalnch is offline   Reply With Quote
Old 04-12-2013, 09:50 PM   #4
Rhyder
interesting thx, do you have a vert or a coupe?
Old 04-12-2013, 10:10 PM   #5
Avalnch
Avalnch's Avatar
No, mines a 2010 coupe. I'm not sure what year they switched over from FE3 to FE4, but I think I read that some model years had them both. Might have been 2012??
You can easily tell what sway bar you should need by just checking under the rear of your car. If rear swaybar endlinks are oriented same as the front (meaning they go through the bar horizontally), then you have the FE3 suspension. If you have vertical endlinks (the nuts are on the top and bottom) then you have the FE4/FE5.
Good Luck.
Old 04-12-2013, 11:48 PM   #6
SSMickey
SSMickey's Avatar
Drives: 2010 IBM 2SS
Pull up the carpet in your trunk and on the left side of the floor is a tag with a bunch of codes on it. Look for FE3, FE4 or FE5. If you have FE3, you will need a new bar or new lower control arms to install the bar you have. If you have FE4 or FE5, you need a new shop that knows what there doing.
ProCharger P1X, Vengeance Racing Kaotic Cam, ARH Headers and Exhaust with Borla ATAK mufflers, MGW Shifter, MTI Drop Springs, Forgeline RB3C Wheels, 3.91 gears, Night Owl LED Control System
SSMickey is offline   Reply With Quote
Old 04-13-2013, 12:39 AM   #7
sting808
Drives: 2010 SS RS
What type of wheels are you running? The 1st pre-order, ver 1, slightly scraped my CCW 20x11.5 on bumps. Had about 3/8" clearance at 1" drop. If you're running fender flush 20x11 or smaller, should fit.
The new versions is suppose to be slightly narrower.
NOTE:
Must use the outer arm mount, not the inside tab. If your OE bar is like a "U", you may not have the newer lower control arm. Check out this thread.
http://www.camaro5.com/forums/showth...=197523&page=6
(post #149)
It shows the hole needed in the lower control arm for the the new ZL1 style swaybar.
sting808 is offline   Reply With Quote
Old 04-13-2013, 08:24 PM   #8
ICTsccaCamaro
Drives: 2018 ZL1 1LE
That is a fe4 and up rear bar you will need new lower rear control arms and links to run that on a 2010 or 2011
ICTsccaCamaro is offline   Reply With Quote
Old 04-14-2013, 02:38 PM   #9
Rhyder
interesting, I was not aware they had both in 2012, will have to look to see. Thx for the input.
This was the first full Pedders install I believe of bushings and everything for MTI racing, but they did an astounding job on everything, and they have been working on 5th Gen and corvette's for a long time.
I'm leaning more towards it being the incorrect bar for my specific car, be it not an FE4 as I thought all 2012's were or the bar for a vert is different than one for a coup, and I got the bar for one or the other.
I put it in as a 2012 SS FE4 Vert.
Pedders has stepped up to the bat on a few things right away, Im sure they will take care of me on this, just wanted to identify where the dialog needed to start on my end as this is the first suspension type mods Ive ever ordered, much less had installed on a vehicle.
By the way, its a completely different car handling with all the bushings, coilovers and front sway bar on it, handles crazy good. Not sure how much a difference getting the correct rear sway on will make but Im looking forward to it.
And I would highly recommend MTI Racing if your getting work done on your car, suspension or performance, in Atlanta GA or surrounds. They do go the extra mile and take the time to get it right and perfect before you get it back. And they keep you updated really well.
Old 04-14-2013, 03:24 PM   #10
Top Off
Drives: 2012 LS3 1SS/RS Vert
I'm pretty sure the verts, at least the 2012. Still are FE3 suspension.
Top Off is offline   Reply With Quote
Old 04-14-2013, 04:06 PM   #11
Rhyder
I believe your correct ...at work havent looked yet, but looking at a GM site it has this in it
"FE4 Suspension
With a focus on refined handling, the FE4 package — exclusive to the Camaro SS coupe "
http://gmauthority.com/blog/2011/04/...vrolet-camaro/
Though going through the actual Chevy site archived pages, it says the Convertible has the FE4 suspention.
I guess Ill have to just pull up the carpet or jack the car to look at the sways to be sure
Old 04-14-2013, 04:27 PM   #12
Rhyder
So I would say from the above posts, my car has an FE3 suspention....guess I will look into the rocker arms mentioned maybe.
Thanks for the help.
Old 04-14-2013, 05:56 PM   #13
danvillekidd
2013 ZL1
danvillekidd's Avatar
Drives: 2013 ZL1 m6
Yes that would be the FE3. The new sway you have may still be the correct one for FE4 and all you would need to do is change the RLCAs to the new style, if you don't have them already. I did the same thing on my '10 and everything fit great.
danvillekidd is offline   Reply With Quote
Old 04-14-2013, 06:06 PM   #14
Rhyder
It also explains what the shop was saying, from looking at pictures the FE4 goes outside the struts, the FE3 inside. So the bar I have now would of been to long when compared to the one on the car now.
