Old 04-13-2013, 03:13 PM   #1
Jbcamaro
Jbcamaro's Avatar
Drives: 2010 camaro
Rs headlights and drls swap
Is it possible to take a rs switch out of my 2ssrs , change it to the regular 2ss switch and change out the headlights to the normal lights and drls to fogs? If so what all would I need to accomplish this
Jbcamaro is offline   Reply With Quote
Old 04-13-2013, 04:14 PM   #2
sjmautoprod
sjmautoprod's Avatar
Drives: '16 2SS
Wow. An RS guy that wants non-RS lamps? People truly do want what they don't have.
So, safe to say that you just want halogen headlamps and control over the DRL's (like fogs)?
You would at least need a headlight harness (4-to-3 wire conversion). Note that the RS high-beam circuit cannot drive the non-RS high beams directly.
I do know that the RS cars don't have the wiring to support a non-RS switch, but, I believe that Ofer has shown a harness to do this.
You could also just wire them to a regular switch.
sjmautoprod is offline   Reply With Quote
Old 04-13-2013, 04:18 PM   #3
Jbcamaro
Jbcamaro's Avatar
Drives: 2010 camaro
Okay thank you very much. So just get the regular switch?. And the reason I want to switch it over is bc of a project. I love my headlights. I just hate the drls. I love the regular switch instead of the rs switch put in the car. I will keep my rs headlights to put back in later after the project. But at the moment I need cheap lt headlights that come on the camaro and the regular fogs
Old 04-13-2013, 04:37 PM   #4
sjmautoprod
Drives: '16 2SS
By regular switch, I mean a standard SPST/SPDT switch, not the non-RS headlight switch, to drive the DRLs.
There are some non-RS lamps on ebay now for $125 each. You may be able to find take-offs from people here for less.
You would also still need harnesses to convert the headlamp connections from 4 to 3-wire and to drive the high beams.
Old 04-13-2013, 09:25 PM   #5
Jbcamaro
Jbcamaro's Avatar
Drives: 2010 camaro
Thank you very much for your help man
Old 04-13-2013, 09:38 PM   #6
The Stig
knows 2 facts about ducks
The Stig's Avatar
Also - 2SSRS is working on / finalizing a harness that let's us RS guys use the non-RS headlight switch.
Click to view my build thread
Old 04-13-2013, 09:51 PM   #7
Jbcamaro
Jbcamaro's Avatar
Drives: 2010 camaro
How long has he been working on that Stig?
Old 04-13-2013, 10:12 PM   #8
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
I did not help that the tester did not install and test for 4 mouths, it all works but one small wire that i need to fix 10 min job.
