Old 06-23-2009, 11:48 AM   #1
destroyer4
destroyer4's Avatar
Drives: 2010 Camaro SS, 2006 PT Conv.
Send a message via AIM to destroyer4
Nitrogen???
Hey all, look through the search and didn't see anything. Is anyone putting nitrogen in their tires? I've had it done on a few cars and it is a noticeable difference. I don't really check MPG's on my PT so haven't noticed on it, but have heard there is a difference.
Anyone????
Cyber Gray/Black/Black Stripes,2SS/RS,Auto
1100, Preliminary order accepted 10/16/09
3800, Order produced 6/22 Vin:2G1FK1EJ9A9120942
6000, Delivered to the customer
7/7/09
destroyer4 is offline   Reply With Quote
Old 06-23-2009, 12:07 PM   #2
Chevyboxer
Drives: 1995 Silverado
I've heard it is not worth it from a few of my engineer buddies. They have basically said what this post is saying.
http://blogs.consumerreports.org/car...en-tires-.html
http://blogs.consumerreports.org/car...nitrogen-.html
Chevyboxer is offline   Reply With Quote
Old 06-23-2009, 12:10 PM   #3
destroyer4
destroyer4's Avatar
Cool, thanks for the article. Although I don't pay for it. Wondering if anyone saw benefits on their cars.
7/7/09
Old 06-23-2009, 12:53 PM   #4
ShnOmac
The other side of the coin.....
We use it in alot of our gear just because of the oxidation factor.
http://www.getnitrogen.org/why/index.php
"If you are one of the 85% of Americans who don't regularly check tire pressure, you neednitrogen.
We take in nitrogen with every breath. Air is composed of:
1% Water Vapor and Other Gases – Escapes up to 250 times faster than Nitrogen
21% Oxygen – Escapes 3-4 times faster than Nitrogen
78% Nitrogen – The largest molecule in air, dry, non-flammable. Because of their large size, nitrogen molecules are the least permeable and stay in your tire longer.
It's not about the nitrogen. It's about reducing oxygen, water vapor and other gases. By reducing the percentage of oxygen, water vapor and other gases in your tires from 22% to 7% or lower, your tires will maintain proper pressure longer than if you use “plain old air.” For example, with 95% nitrogen in your tires, they retain optimal pressure three to four times longer.
Proper tire pressure is a big deal. Maintain it with nitrogen, and you'll see these three primary benefits:
Increased Fuel Efficiency – Correct tire pressure keeps the manufacturer's recommended “contact patch” on the road. This lessens the rolling resistance and maximizes fuel efficiency.
Longer Tire Life – When it comes in contact with other materials, oxygen causes oxidation. Oxidation can make rubber brittle and cause it to lose tensile strength. In addition, at high temperatures and pressures, oxygen reacts and damages inner tire liners and belt packages; nitrogen does not.
Increased Safety – Under-inflated tires cause 90% of blowouts. Nitrogen provides more reliable pressure for reduced blowout potential.
Other benefits:
Improved TPMS Performance – If you have a new car, you likely are plagued by a flashing light telling you your tire pressure is low. For example, one woman's light was going off every four to five weeks. After inflating with nitrogen, her light didn't reappear for 53 weeks!
More Predictable Pressure Fluctuation – NASCAR teams use nitrogen so they can more accurately predict tire pressure fluctuation. Regular compressed air can fluctuate considerably when water vapor is present.
Longer Rim Life – Rim rust caused by condensation from water vapor and other gases can get caught in valves and create slow leaks in tires. Nitrogen is completely dry, so it eliminates the potential for condensation. Why not eliminate all oxygen and water vapor?
What's right for me – 95% or 98%?
Numerous studies have proven that nitrogen in tires reduces the volume of gases that escape more quickly and cause damaging oxidation. However, research also has shown that nitrogen purity beyond a certain point does not provide additional benefits. In fact, with a nitrogen purity above 93.4%? in passenger tires, oxygen actually begins to migrate back into the tire. You can get all the benefits of nitrogen with a purity level between 93-98%.
Bridgestone/Firestone researchers say that 93-95% nitrogen is all you need.
According to Ford Motor Co., there is no difference between 96% and 99% nitrogen purity.
Who Else Is Using Nitrogen?
NASCAR - NASCAR teams use nitrogen because it allows them to more accurately predict tire pressure fluctuation. Nitrogen fluctuates with temperature change, but it does so less than when water vapor is present. Read On... In addition, higher nitrogen levels eliminate the explosive properties of oxygen (oxygen loses its explosive properties at around 9% or less) Read On... NASCAR uses bottled nitrogen for portability. The bottles are delivered to the track by Praxair.
Commercial Airlines – The Federal Aviation Administration (FAA) requires nitrogen in all commercial aircraft tires to eliminate the potential for water vapor (inherent in normal compressed air) from freezing at high altitudes. In addition, aircraft manufacturers such as Boeing use nitrogen membranes in their On-Board Inert Gas Generation Systems (OBIGGS) to "top" fuel tanks with nitrogen - an inert gas that does not support combustion.
U.S. Government – NASA and the U.S. military use nitrogen for many of the same reasons it used in commercial aircraft.
Food Processors and Packagers – Oxygen hastens both the chemical breakdown and microbial spoilage of many foods. Think meat, potato chips, cookies, etc. To help preserve foods longer, processors and packagers often use modified atmosphere packaging (MAP) and controlled atmosphere packaging (CAP) that replaces some or all of the oxygen in the air inside the
package with nitrogen.
ShnOmac is offline   Reply With Quote
Old 06-23-2009, 12:56 PM   #5
destroyer4
destroyer4's Avatar
Lots of great info here. Thanks.
I see your in the Mid east.
I thank you for that also.
7/7/09
Old 06-23-2009, 01:13 PM   #6
ShnOmac
Thank you
Old 06-23-2009, 01:28 PM   #7
trudawg660
Drives: 2006 Dodge Charger / 2SS IOM
i lot of americans dont check their air pressure but now the cars do it themselves. and it will tell you if it is too low
trudawg660 is offline   Reply With Quote
Old 06-23-2009, 07:28 PM   #8
The Viz
The Viz's Avatar
Drives: Everything
we put it in every car at PDI
The Viz is offline   Reply With Quote
Old 06-23-2009, 09:32 PM   #9
Parker
Parker's Avatar
Drives: 2010 Camaro SS/RS
I'd have to say its not worth it, the car comes with an air compressor and full tire monitor system, free air for life. As far as oxidation goes its painted aluminum wheels will take a few decades to oxidize to a bad point, the outside will probably be worse at that point, same goes for the tires. Besides if its not medical grade nitrogen it's most likely gonna have the same crap an air compressor adds to the mix.
just don't forget to add air once in a while. I personally like to go 1-2 pounds over because I usually end up with more even tread wear.
Parker is offline   Reply With Quote
Old 08-02-2009, 11:15 PM   #10
superstockcam
Member
superstockcam's Avatar
Drives: 2010 ABM 2SS/RS LS3
Oh man!! all four tires completely flat.
Seriously though, I put nitrogen in my tires since I noticed a 5-6 psi increase from 72 degrees in the garage to an on the road temp of 95+. Now with the nitrogen they change just 1 psi. assuming you evacuate all the air out of the tire to oh lets say a 5" vacuum. sensors still work too! man I sweated that one, vacumming may not be good for them?? but just flatening them and adding nitrogen it still changed +3 psi. The ride is very consistent now and I dont have to sweat hard tires while ripping around the mountain curves. PS slime in the tire will result in instant tire sensor death according to all I speak to!
________
PISSING VIDS
superstockcam is offline   Reply With Quote
Delusional Dealers pruettfan Camaro Price | Ordering | Tracking | Dealers Discussions 19 05-18-2009 10:23 PM
Shell Gasoline Muscle Master General Automotive + Other Cars Discussion 13 03-16-2009 04:06 PM
GM VP projects 30% of Camaro sales to be V8 version. 3.6L to get 27mpg highway Sphinx002 5th Gen Camaro SS LS LT General Discussions 48 06-09-2008 12:29 AM
