Old 04-14-2013, 10:48 PM   #1
StlRomAniaN
StlRomAniaN's Avatar
Drives: IOM 2010 Camaro 2SS/RS
Pedders Rear Xa Coilovers
I need to lower my rear about 15 mm. How much should I lower the rear coilover to achieve that? Hopefully someone from Pedders can chime in!
I spun the bottom piece up 2 full spins and it only lowered it 5 mm?
StlRomAniaN is offline   Reply With Quote
Old 04-14-2013, 10:56 PM   #2
TBone
Negative Camber Junkie
TBone's Avatar
Drives: 2010 1SS LS3/6MN ABM 1 of 23
I would say 4 more spins then.
Lowering with coilovers is all about adjust, check, adjust, check, until you are at the height you need. There is no set amount of "spins".
T.
"Horsepower is something that looks great in a Magazine article, but suspension is what actually gets you around the track fast.." Jack Olsen
The drag strip is like sniffing glue, it's cheap, it's a decent buzz, it doesn't last long and they are all the same.
Road racing is like China White Heroin, the buzz is stronger, the high lasts for hours, it's extremely addictive and they are all different.
I can't wait for my next
Track fix.
DA HAWKS OWN DA CUP!!!!!
TBone is offline   Reply With Quote
Old 04-14-2013, 11:01 PM   #3
StlRomAniaN
T.
There should be a set amount of "spins". For instance, 1 thread (1 mm) on the coilover equals 1 mm of drop for the front. However, I know that the rear has a different ratio, which I'm trying to figure out.
Old 04-15-2013, 08:54 AM   #4
seddon
seddon's Avatar
Drives: 2017 ZL1
Just move the colloar or locking nuts down 15mm and you should be close.
Elite Design Concepts NY5THGEN2017 ZL1 Garnet Red/M6/// IG @Crazl1
seddon is offline   Reply With Quote
Old 04-15-2013, 04:24 PM   #5
JDP Sales
JDP Sales's Avatar
Drives: Chevys at the limit
However far you move the lock rings, should translate to roughly the same change in ride height. But as T-bone said, it is a process of adjust, check, readjust check until you get her dialed in. Feel free to call, PM or email me anytime with questions.
Best regards,
Tyler
888-308-6007
Old 04-15-2013, 07:13 PM   #6
StlRomAniaN
Thanks for the suggestions. I'll take a day out to do that. Is it possible that the bushings are holding it up? The bushings where the camber bolt holds the LCA on.
