Old 04-14-2013, 10:59 PM   #1
lionssfan
lionssfan's Avatar
Drives: 2010 2ss camaro
pedders coilovers attach to stock sway bar?
I have the pedder front coilovers to put on does the stock sway bar and links hook to this ok thanks
lionssfan is offline   Reply With Quote
Old 04-15-2013, 12:29 AM   #2
My 5th
My 5th's Avatar
Drives: 2010 2SS/RS M6 Black on Black
If you're using the stock sway bar, yes. If you're using Pedders front bar you will want to use Pedders links, they are stronger and have better joints.
Meh
My 5th is offline   Reply With Quote
Old 04-15-2013, 07:08 PM   #3
lionssfan
lionssfan's Avatar
thanks i do have the pedder sway bar for the front but not on the car. i having the coilovers put on and didn't have time to figure out what to cut the rods too. Pedders kit didn't come with any instructions that made sense. I need more time to research it. thanks for the info I needed for now.
