![]() Drives: 2010 Camaro 1LT Join Date: Jun 2010
Stupid question, dealer is "recommending" some service...
My 2010 LT1 (A6-V6 of course) just hit 50k.
Dealer mentioned getting the rear differential liquid changed as well as a fuel-injection cleaning. Is this rational to do @ 50k or am I being a prude? The car drives just as good as it did off the showroom floor and is bone-stock. Thanks! |
#2 | |
I'll be back...
Drives: Subaru, HD Road Glide Special Join Date: Apr 2012
Bye bye, Bumblebee!
#3 | |
knows 2 facts about ducks
Excellent, thanks guys!
I like to take care of my car but in this "up-sell market" it's hard to separate the BS from the logic. |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2SS/RS Join Date: Sep 2008
Depending on how you drive, you should have changed the differential fluid 25k miles ago. It's really simple to do, you can easily do it yourself. If you change your own oil then you can do this.
#6 |
![]() Drives: 2013 2SS Convertible, LS3 Join Date: Mar 2013
Buy a can of BG treatment and do the injector cleaning yourself for half the price.
#7 | |
Drives: 2010 SS 426 V8 M/T Join Date: Aug 2012
Not sure about the fuel injection cleaning. I only use premium and change my oil every 3-5 k miles |
#8 |
![]() Drives: 2017 Camaro SS Join Date: Oct 2009
Fuel injection cleaning is a waste of money if your car is running right.
#9 | |
Most additives, I would agree. But I have seen good results from BG. |
#10 |
I have owned over a half dozen cars with over 200,000 miles on each one and never cleaned the fuel injection. Guess I was just fortunate.
#11 |
I have had a few occasions of engine running poorly, using BG and having the engine run beautifully afterward.
So I developed a habit of running the treatment every 50k or so miles. No troubles since. Could depend on fuel quality, I would think. |
#12 |
![]() Drives: 2013 2SS/RS M6 NPP Join Date: Dec 2012
Fuel system cleaners are needed to some extent. There are those out there that fill up at mom and pop stations that do not see much turnover so the fuel isn't the quality it could be. Case in point, my parents purchased from a small store because it was the cheapest around and they had issues with their fuel system. This was in a VW, and not a GM product. Cleaning the fuel system solved their problem. Since then they buy from a station that has a high turnover of fuel, so it is basically fresh, or at least more so than the previous station.
Plus, deposits are going to be an issue with direct injection coming to the main stream. Already seeing some of it in UOA's, (used oil analysis). Run some cleaner in the fuel system and the UOA comes back next time around improved. |
