Eh, that'll happen
Drives: 2010 2SS Join Date: Apr 2012
Billet Cap install question
Hey guys,
Ive never done diff work so any and all help is appreciated. I am wanting to buy a brand new 1LE diff, but before I install it, I would like to put billet caps in it to add some strength. Is that something I can do at home? I would rather not buy the diff, send it out to be worked on, and then have it sent back to me. Makes it expensive. I know about the exchange programs through a couple vendors but dont really want to go that route because I want new parts, not something someone beat the shit out of. Can I just undo the cover, swap out caps and call it good? Thanks!!
2010 Camaro SS LS3 - No Modz
No, you can't. The mounting surfaces of the JRE Billet Caps must be precision machined to meet a specific diameter. There are installation instructions available on Jannetty's website. But since the carrier has to come out anyway, this would be a good time to install the JRE posi-mod or better yet, the Eaton TrueTrac.
Eh, that'll happen
Thanks for the response.... not really the one I was hoping for though. Lol! I have definitely been looking into the TruTrac, but by the time I have Jannetty build one, Im in it for $3900, (dont want to send mine in for core charge. $1200 for a core charge is ridiculous...anyway) $1500 more I could get a hammerhead. Was hoping to build a stout 1LE diff since my driving style is not abusive enough to justify 12bolt/9in. Oh well, thanks for the help!
Why buy an entire new differential???....you have the same exact differential already, just with different gears!!! Just buy the parts and have a "knowledgeable" shop install them....
3.91 Gears = $250 TrueTrac Posi = $550 Billet Main Caps = $170 Install "half" kit = $130 Total Parts = $1100 Labor = depends on how much you're willing to do yourself!!! This route will give you a BETTER rear end than a stock 1LE rear end....and for less money. |
Drives: 2012 Camaro RS, RX supercharged Join Date: Dec 2009
blazzein is correct. We do the JRE clutch & since we are a machine shop do the billet caps on most as well.
This is something we do in 1 day for customers....true trac as well if desired. |
#6 |
If you can remove and install the "pumpkin" out yourself, you will save a ton of labor costs. Plus, when I removed my carrier and gears (to replace them with the TrueTrac and 3.91's), I sold the original posi-unit and gears together on the Camaro5 classifieds for like $375!!!
#7 | |
knows 2 facts about ducks
Sorry, your placement of the quotes was just kind of funny. |
#8 |
Well, however you want to say it.....Just use a shop that knows what the hell they're doing!!!! That's what I was trying to say!!!
#9 | |
![]() Drives: Black 2SS/RS M6 Join Date: Mar 2010
2010 LS3 2SS/RS M6
AirAid Cold Air Intake, AAC LED sidemarkers, AAC P13w plasmas drl, Kook's Custom 1-7/8" Headers, Corsa Hybrid Exhaust JRE 445 Cam Package, JRE SCT Tune, RX Catch Can and Breather Tech AFX Heater Hose Relocation Kit, Black Chrome Wheels Pfadt trailing and toe arms, Pfadt solid subframe mounts, Pfadt diff bushings, Street Slayer Twin Carbon Technostalgia Camaro LED taillights, CTS-V Front Brakes, Powder Coated Calipers By ME MGW Short Throw Shifter Complete ZL1 Rearend Swap |
#10 |
#11 | |
#12 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 2SS/RS & 2017 1SS Join Date: Apr 2011
Yea, either way, if your are going to do it, do it correctly the first time. Gears with Posi with Caps. IMHO
2011 Chevrolet Camaro 2SS/RS L99 (1 of 782)
10.78 @125mph ALL MOTOR SBE Built/Tuned by Me 2017 Chevrolet Camaro 1SS Auto 9.29 @144.57mph ALL MOTOR SBE #TEAMGPI Gwatney Performance Innovation |
#13 |
Make your peace with God!
Drives: 2011 Camaro SS/RS M6 Convertible Join Date: Dec 2011
The Hammerhead is a pricey unit. Which is why I didn't buy one, but rather built my existing stock unit to match the Hammerhead. The only difference between my unit and the Hammerhead is the casing and diff cover. At the end of the day you're talking about about $2000 out the door to have it built with all the same parts.
ECS base supercharger (NOVI 1500SL), ECS AlKY control kit, 92mm TB, ARH 1 7/8" LT's non-catted, Borla 3" exhaust, ID850 injectors, Squash fuel system, ECS Big Blower Cam, MGW short throw shifter, DSS 1000hp axles, LGW differential cover, billet caps, Tech AFX heater hoses, Pedders differential bushings, Eaton TrueTrac differential, PRC dual valve springs, Katech C5R timing chain, ATI balancer, Meilings oil pump, Pfadt Trailing Arms, Pfadt Tie Rods, Pfadt Sway Bars, Pfadt End Links, DSS Aluminum Driveshaft
811RWHP/719RWTQ UNDER MAJOR OVERHAUL!! |
#14 | |||
Eh, that'll happen
Because I cant have the car down to pulll the diff and send it out. Was just thinking I could buy a new diff for $1600, put caps in it, and have a stout brand new diff for $1750
None, I dont have any diff experience. Ill take it out, but thats the extent of the work I can do! Lol! Quote:
That has been my number 1 option for the last couple months. A couple weeks ago, I bought some GFORCE axles for a racing event that didnt make in time for me to use. Since the axles cant be used on the ZL1 diff, I started looking into building the stock diff up. Theyre still in the box but dont want to sell them because then Im going to lose money. At least thats my thought process now. Quote:
