Old 04-21-2013, 09:30 PM   #1
IPT
Drives: '02 Trailblazer, '12 Camaro 2SS/RS
ZL1 pedals installed : ).
FInally got 'em done. Wasn't as bad as I thought it would be wrestling them on there. Really changes to look when you open the door .
IPT is offline   Reply With Quote
Old 04-21-2013, 09:43 PM   #2
Toms2010
Drives: 2010 2LT
Looks great.
2010 2LT CGM Auto
Vararam CAI - Modern Muscle Ported Throttle Body - Vmax Black Iceolator - Custom Exhaust - Magnaflow Res X 11386 - 2.5" Pipe from X on Back - Magnaflow Round Mufflers 10416 - Lime Green Hood Spears - Lime Green Gill Stripes - SJM AutoProd Sequential Turn Signals - SJM AutoProd Always On DRL Fog Lights
Toms2010 is offline   Reply With Quote
Old 04-22-2013, 06:13 AM   #3
DFWHD
Drives: 45th Anniversary Convertible
Looks great! How do these detach/attach? I'm looking at doing this as well...
DFWHD is offline   Reply With Quote
Old 04-22-2013, 06:17 AM   #4
menendez1293
Emerald Coast Camaros
menendez1293's Avatar
Drives: 2010 Camaro 2LT/RS M6
The clutch can break just slip on. They are kind of like a rubber cover. The gas pedal I believe has 2 bolts and a sensor/ harness. I have them on my list of to do mods and they actually aren't to expensive
But OP they look great
Old 04-22-2013, 02:17 PM   #5
IPT
Thanks . I was really pleased with how they came out. Yes, the brake and clutch "just" slip on. The old covers slip off pretty easily they are much more maliable than the new ones. The new ones are tighter, stiffer, and need some finagling. I used a heat gun to soften the rubber and a screw driver to pry the upper lip up and over the actually pedal during the install. I have read some folks bake the pedals in an oven first to soften them up. My finger tips are a little sore from the process of pushing and pulling on the tough and very warm material, but I'll survive .
The accelerator is as stated, a few bolts (3 actually) and a wiring harness. WAY easier than the brake and clutch pedals . Unbolt it, drop it down, pop the harness, snap harness into new pedal, bolt back to the floor. Wha-la.
Old 07-29-2013, 10:27 PM   #6
WillTuker
Drives: 2013 Camaro 2LT RS Victory Red
I'm having a lot of trouble with installing the covers... Any more suggestions ??
WillTuker is offline   Reply With Quote
Old 07-29-2013, 10:57 PM   #7
Aubrey64
Aubrey64's Avatar
Drives: 2010 Camaro LLT/RS
Looks good!
Aubrey64 is offline   Reply With Quote
Old 07-30-2013, 09:53 AM   #8
kanman99
Drives: 2013 RS/SS
where did you find the pedals and how much?
kanman99 is offline   Reply With Quote
Old 07-30-2013, 07:57 PM   #9
The Blue Ox
The Blue Ox's Avatar
Drives: 2010 SS L99 Inferno Orange
The Blue Ox is offline   Reply With Quote
Old 07-31-2013, 04:40 PM   #10
Nemax
Nemax's Avatar
Drives: 2012 Camaro 1LT/RS
I would like to know this aswell.
Nemax is offline   Reply With Quote
Old 07-31-2013, 04:41 PM   #11
Vengeance Graphix
Vengeance Graphix's Avatar
looks good
Old 11-23-2013, 12:26 PM   #12
IPT
sorry guys, just saw this now. I got them from GMpartshouse here (few items down the page):
http://store.gmpartshouse.com/partlo...egoryID=161270
The install is a bit of a wrestling match but really not as bad as what I thought it would be from other posts I saw. The pedal covers slip over the metal pedal. So it's sort of like a mattress cover. I found it fairly easy if I slid the cover up from the bottom. Then the bottom of the pedal seats itself seats into the pedal cover. Then you just need to pry the outer edges of the cover over the top. That is the part that's a pain. I used a heat gun (before I slid the cover on) to make the rubber soft. I used a small screwdriver to lever the upper rubber lip over the top corner one on side. Keeping upwards pressure from below so the cover didn't slip off again I then pried the top part, and finally the opposite corner up and over the metal pedal itself. With the rubber real warm and malleable and a small screwdriver it really went pretty easily.
