Old 04-22-2013, 02:26 PM   #1
franknbeans
Whipped
franknbeans's Avatar
Drives: 2010 CAMARO
Pedders ZL1 Sway Bar Question.
Hey guys,
Just did a huge mod weekend and got the Pedders Rear Cradle bushings in and did a Front and Rear Pedders ZL1 sway bars.
My question is, why are the endlinks from Pedders so strange?
By that I mean, what are there so many bushings.. solid space rode, bushings, washers..
They were a huge pain in the ass to put in.
Not sure why they are not like the ones pictured here. (found on the web)
franknbeans is offline   Reply With Quote
Old 04-22-2013, 06:09 PM   #2
TBone
Negative Camber Junkie
TBone's Avatar
Drives: 2010 1SS LS3/6MN ABM 1 of 23
The end links in the bottom two pictures are the stock ones from GM.
Not sure how the Pedders ones are different, except the are RED.
How were they difficult to install? It is a bolt that goes through all of the bushings, rod, washers and then a nut on top.
T.
"Horsepower is something that looks great in a Magazine article, but suspension is what actually gets you around the track fast.." Jack Olsen
The drag strip is like sniffing glue, it's cheap, it's a decent buzz, it doesn't last long and they are all the same.
Road racing is like China White Heroin, the buzz is stronger, the high lasts for hours, it's extremely addictive and they are all different.
I can't wait for my next
Track fix.
DA HAWKS OWN DA CUP!!!!!
TBone is offline   Reply With Quote
Old 04-22-2013, 06:51 PM   #3
franknbeans
Whipped
Drives: 2010 CAMARO
yeah a bolt that goes through it the whole thing... sucks
Old 04-23-2013, 07:52 PM   #4
Rob@WretchedMS
Drives: His Wife Crazy
The Bushings go above and below both the swaybar and the control arm.
Starting from the top
Washer
Bushing
Swaybar
Bushing
Washer
Spacer
Washer
Bushing
Control Arm
Bushing
Washer
Does this help?
Rob@WretchedMS is offline   Reply With Quote
Old 04-23-2013, 09:50 PM   #5
enyce0387
enyce0387's Avatar
Drives: 2011 camaro 2ss/rs ls3
how much better are the new sways? just ordered the same setup im coming from pfadt sport bars.
enyce0387 is offline   Reply With Quote
Old 04-23-2013, 11:03 PM   #6
Rob@WretchedMS
They are very nice, it's hard to put a number to 'how much better', but people have been very happy.
Old 04-24-2013, 11:59 AM   #7
franknbeans
Whipped
Drives: 2010 CAMARO
no no.. I understand how they go in.. mine's already in.. just don't understand why all the bushings and washers instead of a design like the other picture.. I guess OEM
Old 04-24-2013, 12:04 PM   #8
franknbeans
Whipped
Drives: 2010 CAMARO
You have to stick you pinky up in the hole to hold the bold and all the washers, bushing, spacer from dropping off.
Old 04-24-2013, 12:32 PM   #9
franknbeans
Whipped
Drives: 2010 CAMARO
We could only get the end links in with full weight on the suspension. Is this correct?
And that is barely in.
Old 04-24-2013, 02:08 PM   #10
Rob@WretchedMS
They should be tightened with the weight on the wheels,
as long as there are some threads protruding from the nut you should be ok.
Old 04-24-2013, 08:27 PM   #11
enyce0387
enyce0387's Avatar
mine will be delivered tomorrow! thanks for all your help so far Rob A+ customer service!
Old 04-24-2013, 08:36 PM   #12
Rob@WretchedMS
Thank you for the Business!
Old 04-25-2013, 10:38 AM   #13
caverman
caverman's Avatar
Drives: '69 SS Convertible
The stock ones do the same thing. There is a bolt inside that black tube/sleeve. When installing mine what I didn't know is if the nut was supposed to be at the bottom under the LCA or at the top so I guessed going by basics that the nut typically goes on the bottom. It may not make a difference either way though.
I've never seen Pedders drop links in person but my guess is that the difference is that Pedders probably uses a metal sleeve vs OEM which is more of a plastic one. Pedders probably uses a larger sized nut/bolt as well. Again, I can't confirm that since I've never seen them in person.
Here in these pics you can see the bolt that goes inside that black sleeve. In the second one is the bolt and the sleeve. The first time I was going to come up and put the nut on top but then decided to flip it an put the nut on the bottom.
Build Journal
Old 04-25-2013, 10:45 AM   #14
caverman
caverman's Avatar
BTW: there are no more bushings than pretty much any typical drop link style end links for sway bars. My '69 front sway bar has the same 8 bushings, 4 washer, 1 bolt setup. The only difference is there isn't a sleeve to go around the bolt.
Build Journal
