Old 04-24-2013, 02:14 PM   #1
kold
kold's Avatar
Drives: 2011 LS White Camaro
squeaking noise on eibach 1inch lowering springs
got them put on about 3weeks ago and now im getting a squeaking noise thats driving me crazy. Any help would be great, tx guys
kold is offline   Reply With Quote
Old 04-24-2013, 02:45 PM   #2
jeremywes
jeremywes's Avatar
Drives: 2012 Camaro SS
Can you tell if it's coming from the front or rear? Did you clock your bushings when you lowered the ride height?
jeremywes is offline   Reply With Quote
Old 04-24-2013, 02:55 PM   #3
kold
kold's Avatar
it sounds like its on the back, and im not sure to be honest i had a local shop install them and then do a alignment
Old 04-29-2013, 11:46 PM   #4
K32 Camaro
V8 lounge member #5
Drives: 12 2SS Synergy Camaro, 05 PontiacG6
That's easy then. Take it back and have them do it right.
K32 Camaro is offline   Reply With Quote
Old 04-30-2013, 12:00 AM   #5
2010SLVRBULIT
2010SLVRBULIT's Avatar
Drives: G5(LLT) & C6(LS3)
have them check to see if the sleeve is where it should be, no metal to metal contact..
Old 04-30-2013, 12:35 AM   #6
CamaroDreams07
CamaroDreams07's Avatar
Drives: Slow V6
Did you have sway bars put on at the same time?
[B]
Old 04-30-2013, 04:56 PM   #7
PfadtRacing
PfadtRacing's Avatar
Drives: 2010 Camaro, 2006 Z06
agreed. The lowering springs typically have coils that will touch and need an isolation sleeve in there to help quite them
