Old 04-25-2013, 12:36 PM   #1
NLDavis
Drives: 2010 Camaro LT
Synthetic Oil
I've taking my camaro to the dealer for its oil changes and decided
I would start doing it myself so I was going to switch to Mobil1 Full Synthetic
5w30 but the dealer said full synthetic is not recommended for the camaro.
Is there any truth in that cuz I've never heard of any car not being able to use synthetic? Any information would be appreciated thank you.
NLDavis is offline   Reply With Quote
Old 04-25-2013, 12:38 PM   #2
nyrfan
Let's go Rangers!
nyrfan's Avatar
Drives: 13' AGM 2SS/RS L99
Your dealer is an idiot, find a new one fast.
FSP tuned: 377/389
Old 04-25-2013, 12:39 PM   #3
Hannibal
Hannibal's Avatar
Drives: Camaro SS & ZL1
Well, they may be telling you that because of the oil consumption issue seen in the LLT engine. One theory is that the full synthetic oil is "too slippery" for the engine and it ends up burning the oil.
Others here will chime in with more info as well. I would stick with the semi-synth stuff that the manual suggests.
Hannibal is offline   Reply With Quote
Old 04-25-2013, 12:42 PM   #4
nyrfan
Let's go Rangers!
nyrfan's Avatar
Tracy in the past has disagreed with this and said all LLT motors should run full synthetic.
FSP tuned: 377/389
Old 04-25-2013, 12:46 PM   #5
Hannibal
Hannibal's Avatar
Yea, I was offering one of the explanations that is being kicked around the C5 site as a possible reason why the dealer responded in the way that they did.
Old 04-25-2013, 12:51 PM   #6
Mydivorcegift
Future Mopar Owner
Mydivorcegift's Avatar
Drives: 2011, 2SS/RS, Synergy
I run Joe Gibbs...
2005 GTO-IBM-A4-Sold
2011 Camaro SS/RS Synergy-1 of 255-Sold
You will be missed but you are in good hands!
2019 Challenger Hellcat
B5, Redeye, Widebody
Mydivorcegift is offline   Reply With Quote
Old 04-25-2013, 12:55 PM   #7
Blau camaro
Blau camaro's Avatar
Drives: #1 CAMARO FAN
I've been using Mobil 1 since the first oil change and not any problems with oil consumption.
Blau camaro is offline   Reply With Quote
Old 04-25-2013, 01:28 PM   #8
lbheat
Echale Gas [COTW 3/10/14]
lbheat's Avatar
Drives: 2010 Camaro SS/RS Supercharged
I use royal purple...try it out
Kenne Bell
502 rwhp/ 471 rwtq at 9psi (daily driver...for now)
Performance: Corsa catback, JRE Super Tensioner, dual pass heat exchanger, R1 slotted & Dimpled rotors cryogenically treated
Cosmetic: Giovanna kilis 22", zl1 mailslot bumper, Custom Emblem Pro Badge, painted calipers
lbheat is offline   Reply With Quote
Old 04-25-2013, 01:41 PM   #9
rking2000
rking2000's Avatar
Drives: 2011 Camaro 1lt r/s
Some years back 2000. I bought my Harley,asked the dealer about Synthetic oil. Oh no they said,to slippery,cause gaskets to leak etc. Just use our oil thats specially blended for Harley engines he said.Well at the time I think there shit ass dino oil was about the same price as synthetic. After talking to others, looking at oil company data,I said what the hell I'm going to try it. Put a temp gun on the heads and I actually had about 25 degree temp drop with synthetic. Air cooled engine -25 degrees with synthetic. SOLD forever. Nowadays new Harleys are running synthetic right from the factory! They still sell there dino oil but guess what, synthetic is about $5-$6 a quart more from them. The dealer isn't very knowledgable, plus I think (i might be wrong) but isn't that Durco or whatever its called a GM oil product?
Just my 2 cents and experiences with dealers and oil
rking2000 is offline   Reply With Quote
Old 04-25-2013, 01:53 PM   #10
Zorns
Zorns's Avatar
Drives: ?
I had an older model Corvette that I put full synthetic in....and it leaked/squirted out all over. Put standard oil back in and everything was fine. That was on a much older engine with quite a few miles on it. I doubt a switch to synthetic would be an issue on a modern engine; although I do remember seeing something about full synthetic not being recommended for the V6...but can't recall what the reasoning was.
Zorns is offline   Reply With Quote
Old 04-25-2013, 02:05 PM   #11
wakespeak
wakespeak's Avatar
Drives: 2020 ZL1 1LE
The Dexos standard essentially requires a semi synthetic at a minimum. Usually synthetics help with oil consumption because they have lower volatility, that is they don't convert to gas when hot as easily. Your dealer is wrong.
You should Google the V-6 and oil consumption. My guess is that it is due to crankcase ventilation, which can suck liquid oil (as well as any boiled off to gas) in through the air intake if not balanced correctly. See all the threads on catch cans. It gets worse and worse over time because the residue from the oil that is burned tends to accumulate in the cylinders and gum up the piston rings causing more oil to get sucked in etc etc. In this extended case regular oil may burn more completely (due to its lower volatility/flash point) and not leave as much residue, so the oil burning levels off at some point.
wakespeak is offline   Reply With Quote
Old 04-25-2013, 02:06 PM   #12
Hyena
Drives: 2013 1LT RS CRT
l
Dexos is the name of the oil.
Hyena is offline   Reply With Quote
Old 04-25-2013, 02:14 PM   #13
FJ60
Drives: '13 2SS RS 1LE ; '85 Landcruiser
My regular mechanic swears by European synthetics over those made in the US. He said US-made Mobile 1 can't compare to the European-made Mobile 1. My experience is my Subaru turbo motor consumed a quart of US-Mobile 1 every 3k miles, but not a drop of Liqui Moly over the same interval.
FJ60 is offline   Reply With Quote
Old 04-25-2013, 02:57 PM   #14
Sir Nuke
Master of All Things
Sir Nuke's Avatar
Drives: '26 Corvette Stingray
BS......not only do I use Mobil1 in my Camaro since day one, I have a Caddy that has the exact same LLT engine in it and it came from the FACTORY with Mobil1 in it. So "whats good for the goose is good for the gander". Thus Mobil1 has been in both from the start.
