Old 04-25-2013, 03:40 PM   #1
blkngldbabe
Barossa's handler
blkngldbabe's Avatar
Drives: 2LT/RS RJT
3.91 1LE gears?
Hey all. I have been contemplating changing out my factory gears. I have an M6 and have been flip flopping between the 3.91 1LE gears or the Richmond 3.73 set up. Surprisingly enough, the GM performace ones for the 1LE are half the price of the 3.73s. I have this one concern though. I drive Barossa full time. All year round.
I want the get up and go, and really, while I prefer the nice fuel economy it's not a HUGE priority. I figure as long as I don't drive like a jerk all the time, it won't be that bad. Any suggestions or advice from people who have made the change, or know people who have?
Thanks in advance.
SLP's GTA Master Specialty Vehicle and Master Parts Dealer
blkngldbabe is offline   Reply With Quote
Old 04-25-2013, 03:51 PM   #2
Jessika
Drives: Anything Blown
I sent you a PM with a link to a great deal on a new diff
Jessika is offline   Reply With Quote
Old 04-25-2013, 04:31 PM   #3
hunterv6
Always bet on Black
hunterv6's Avatar
Drives: 2011 turbo LS, 2012 f 150,
as far as the 3.91 the only pit fall is that first would be useless and you would need a tune to calibrate the odometer. other than that i found no problem with the 3.91 being in the v6 manual hopefully i will have mine installed soon right now there collecting dust in the garage.
<font color=#0066cc>http://www.camaro5.com/forums/showthread.php?t=283263</font>
hunterv6 is offline   Reply With Quote
Old 04-25-2013, 04:34 PM   #4
Sapper12b
HTCC Member
Sapper12b's Avatar
Drives: 2013 Camaro SS
ok so educate me here guys. When changing out the gears to the 1LE or any other type of gears, is anything else required to make the install work?
Sapper12b is offline   Reply With Quote
Old 04-25-2013, 04:37 PM   #5
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
You need the gears, an install kit, and a professional that knows what they are doing.
Old 04-25-2013, 04:39 PM   #6
hunterv6
Always bet on Black
hunterv6's Avatar
Ring and Pinion Gear Installation Kit they make a full and a half kit wear would determine which one you need.
Old 04-25-2013, 04:42 PM   #7
Apex Motorsports
The half kit is a budget option you can go with if you have low miles on your car. If it is my car though, I am going with a full install kit though. If I am putting new gears in there I want all new part.
Old 04-25-2013, 04:44 PM   #8
blkngldbabe
Barossa's handler
Drives: 2LT/RS RJT
My fiance is a certified GM technician and I work at a dealer so luckily I have no issues with that part. How short would 1st be? That could be a concern for winter driving. I could always start in 2nd like I do in deep snow....
Old 04-25-2013, 04:48 PM   #9
hunterv6
Always bet on Black
hunterv6's Avatar
apex chase if memory serves me correct do you still have the stats or link for the gear changes how it affects the v6.
Old 04-25-2013, 04:53 PM   #10
hunterv6
Always bet on Black
hunterv6's Avatar
http://thehorsepowerjunkies.com/vehi...swappin-gears/ i think this will help you
Old 04-25-2013, 04:58 PM   #11
blkngldbabe
Barossa's handler
Drives: 2LT/RS RJT
Thanks so much!
Old 04-25-2013, 05:00 PM   #12
Apex Motorsports
The V6 Camaros come with 3.27s and run 2000 RPM at 70 MPH. Swapping to 3.55s provides an equivalent torque gain of approximately 10% or 27.3 ld.-ft. of torque at the rear wheels and will raise 70 MPH cruising RPM to 2167. Swapping to 3.73s result in an equivalent torque gain of approximately 15% or 41.2 lb.-ft. of torque at the rear wheels and will raise 70 MPH cruising RPM to 2277. Swapping to 3.91 will result in an equivalent torque gain of approximately 20% or 55 lb.-ft. of torque at the rear wheels and will raise 70 MPH cruising RPM to 2463.
Old 04-25-2013, 07:44 PM   #13
htoniv
Drives: Camaro
My v6 actually does 2000rpm at 75mph
htoniv is offline   Reply With Quote
Old 04-26-2013, 12:49 AM   #14
wwoody
wwoody
Drives: 2011 Vert
I spoke with you about 3.91's earlier year and now have them, BUT the guy that was to calibrate and tune my car is having a problem finding a program that will calibrate my 2011 manual. Auto yes. ?? You may want to check yours.
wwoody is offline   Reply With Quote
