![]() ![]() ![]() ![]() ![]() ![]() Drives: 2012 45th Anniversary 2SS Join Date: Mar 2012
Need help ASAP
I need help ASAP! I just painted my new holley valve covers and coil packs. Upon reinstall of the coil packs the car is backfiring and idling really rough. I am only keeping it on for a few seconds. It threw one stabilitrak signal but that was it. I'm at a loss. Now I don't know if I installed the coil packs in the same way they came out. But it shouldn't be doing this.....
Any ideas?!
Sellin Chevy's since '06
definite misfire
'24 CT5 Blkwng CF1&2 6spd manual Coastal Blue
SOLD!'23 CT5Blkwng manual Rift Metallic SOLD!'19 Z06-7Speed and lowered on stock bolts SOLD'02 Z28-Kooks true dual headers/TSP heads&cam/full suspension & Kmember sub40K orig miles. https://youtu.be/h6faSdcvNew TRADED!'17 ATS-V Coupe w/ Carbon Black pkg https://youtu.be/GH_t-R-TJV0 SOLD! '18 ZL1 Mosiac Blk SOLD!'16 SS Sedan-Forgestars/ARH/rotofab TRADED!2014 SS Sedan SOLD! 2013 Blue Ray1SS/1LE 1of20. TRADED! 2012 White 1SS/RS |
![]() ![]() ![]() Drives: 2010 SS L99 Inferno Orange Join Date: Apr 2012
Double check all connections! Sounds like something may not be getting good contact maybe! Check to make sure you have the right plugs going to the right coil also!!
nope. Are the wires all the way on? Both the plug and coil?
#6 |
No, I don't think so!
#7 |
chevy pride
no they are all the same, re check connections and plug wires and unhook battery and try again
#8 |
backfiring??? wait did you switch the coil sides? You kept them on that metal bracket thing and reversed them prolly....like drivers and passengers side.
#9 |
It doesn't matter if you switch the coils around! They are all the same coils!
#10 |
you sure?
#11 |
LOL
#12 |
Sounds to me like something is wrong with the firing order. You may have the coil harness inverted on one side.
#13 |
#14 |
I thought when you removed the coils mounted on the brackets they had to stay on the same side. I know the coils can be moved around from 1 position on the bracket to another, but when removing the bracket with 4 of them mounted they are side specific.
