Old 04-26-2013, 06:01 PM   #1
JohnZ
JohnZ's Avatar
Drives: 2010 Camaro 2LT V6
V6 Automatic Transmission Fluid
Hey guys. 2 questions. First, how often are we supposed to change the transmission fluid? I have 56k miles.
Also, is there a particular type that i should get?
Thanks
Injen CAI, V-Max Throttle Body, Rx 25mm Iceolator, Rx 10mm Plenum Spacer, Mace Ported Manifold, ARK N-II Catback, Trifecta Tune, Rx Catch Can.
BMR Bushing Inserts,Pedders Radius Rod Inserts, Pfadt Sway Bars and Endlinks, LSR Front Subframe Brace
SS Brembo Brakes, Racing Brake Stainless Lines
JohnZ is offline   Reply With Quote
Old 04-26-2013, 06:09 PM   #2
SC2150
Yes, we reccomend trans fluid change every 40k miles. Filter as well. You need Dex VI.
Do NOT put anything else in it.
Old 04-26-2013, 07:19 PM   #3
JohnZ
JohnZ's Avatar
Thanks SC2150! I appreciate the quick reply. Is this what I'm looking for?
http://www.amazon.com/Mobil-103529-U.../dp/B009IF3J5G
Follow up question, what about differential fluid?
