Old 04-27-2013, 03:15 AM   #1
jnp05e
Drives: 2011 LS Orange
Connecting MAF
Just installed a CAI and the service stabilitrack is on and wont turn off. I couldn't get the MAF sensor to reconnect correctly, and I'm pretty sure thats the issue. I pushed the connector back in but the yellow clip wont go back in. I know its a simple, no crap solution but I havent found it yet...solutions?
jnp05e is offline   Reply With Quote
Old 04-27-2013, 01:29 PM   #2
clg_98ta
clg_98ta's Avatar
Drives: 2010 Camaro 2SS
Check the connector to the ABS sensor at the rt-front wheel - maybe it came loose during the install.
Did you disconnect your battery for the install? If so, check the connection/retighten. This message can also appear when your battery is bad or you have a low voltage condition.
cai installation, maf, maf sensor, stabilitrack
