Old 04-28-2013, 05:58 PM   #1
Tweiten
Tweety
Tweiten's Avatar
Drives: 2010 Camaro 1LT RS
Oil Change question?
Not very long ago I got an Oil Change. Don't remember exactly how long but it hasn't been 3,000 miles yet. However, my dash says there's only 19% of oil life remaining? How can this be?
Sorry if this is a "noob" question.
Tweiten is offline   Reply With Quote
Old 04-28-2013, 06:01 PM   #2
was619
Billy The Kid
was619's Avatar
Drives: Cyber Grey 2SS/RS
The OLM(oil life monitering system) probably wasn't reset... if so it would have said 100% right after the oil change. To reset I think you just have to not be moving and then take the option to reset through the DIC(Driver Info. Center)
good luck
Not too noob of a question. often the oil change places don't like to touch too many things like that so that would be the reason why they didnt reset it
CGM 2SS/RS[SIZE="1"]
Performance: LT Headers/Stainless Works cat-back, 225/233 Cam, 1LE 3.91 gears, Custom Tune, BMR suspension,
MGW Shifter, Stainless brake & clutch lines, Ideal G Master Cylinder, 275s on all 4 corners
Aesthetics: ZL1 Spoiler, DIY LED marker lights, AACPlasma DRL, Yellow Calipers, painted factory wheels
was619 is offline   Reply With Quote
Old 04-28-2013, 06:04 PM   #3
Tweiten
Tweety
Tweiten's Avatar
good luck
So should I just reset it now and it will give me a more accurate percentage?
Old 04-28-2013, 06:13 PM   #4
SlingShot
SlingShot's Avatar
Drives: 2012 ZL1 - #670
I would just change it every 5K miles regardless. In another 2K miles get it changed and remind them to reset it.
Old 04-28-2013, 06:14 PM   #5
C586
Drives: 2011 Camaro LS
No because there is mileage on the oil. To make it accurate you need to do an oil change and then reset it.
C586 is offline   Reply With Quote
Old 04-28-2013, 06:16 PM   #6
batman53201
Account not blocked
batman53201's Avatar
Drives: The Batmobile
I dont go by that percentage thing. Every 5000 miles is easy to keep track, and it wont sneak up on you
batman53201 is offline   Reply With Quote
Old 04-28-2013, 06:23 PM   #7
SS785
SS785's Avatar
Drives: Camaro SS
Since we are on the topic, anybody know when a dealer would change your oil based on the OLM? 20%? Based on my driving, it'd be more than a year before I hit 5,000 miles.
SS785 is offline   Reply With Quote
Old 04-28-2013, 06:25 PM   #8
Caddyroger
Caddyroger's Avatar
Drives: 2011 RJT Camaro LT2 RS auto shift
What type of oil did they use? If they used regular non synthetic motor oil the oill life might at it end. If they used full synthetic motor oil then you be able to go the 5000 miles.
A lot of use Mobil1 synthetic motor oil.
Caddy
Caddyroger is offline   Reply With Quote
Old 04-28-2013, 07:09 PM   #9
jd10013
Drives: 2012 camaro
10% by the owners manual. should put you between 5k and 7500k depending on how you drive. thats the beuaty of the OLM, it bases your change interval on your drving habits. where 5k might be perfect for the guy that drives city to and from work 5-10 miles in stop and go traffic 5 days a week, its a complete waste of money for people who only cruise the open roads on the weekends
jd10013 is offline   Reply With Quote
Old 04-28-2013, 07:34 PM   #10
skibik
Guest
Drives: bbbbbb
I would mark the current mileage, not bother with resetting the oil life just yet and see when it tells you to change. You said you changed less then 3000 miles ago, I would say go another 2000 maybe 3000 and then change unless you have a set interval you were going to change at and take that into account. I have the LFX engine and had planned on 7k oil change intervals but the system come up to change at around the 5700 mark in the last change. The system takes into account a lot of factors. Mine told me to change when it hit less then 5% oil life left.
Dean.
skibik is offline   Reply With Quote
Old 04-28-2013, 10:10 PM   #11
Fast6.3
Fast6.3's Avatar
Drives: 2016 2SS coupe 2015 3LT Stingray
My olm usually gets to like1/5% at about 7000 miles if you got 1/9%left and you driven about 3000 i would leave it untill it tells you to change it than reset it after you change it
Its rel easy when your in park keep pushing the button on the dic until it shows oil life shows than keep it pressed until it resets
Ported intake manifold and throttle body kooks 2" headers no cats
Fast6.3 is offline   Reply With Quote
Old 04-29-2013, 12:47 PM   #12
Jay&Ellie
Drives: 2010 Camaro V6
I'm glad to hear other people doing it every 5k. That's how I do it and it is very easy to track. Doing it every 3k miles to me is a waste of money unless you drive it very hard or live in a very dusty place (El Paso, etc). Most owners manuals state 7500 but I don't have mine because I got it used. I've seen people on here saying the more often the better, and I guess in theory that is 100% accurate. But whether it is completely necessary (monetary concerns, type of driving the individual does, the return on your investment i.e.-increase the engine life from 210,000 to 215,000 miles vs the investment needed to do so) is another question.
Regardless, we all love our cars and will do what we feel is right.
Jay&Ellie is offline   Reply With Quote
Old 04-29-2013, 02:52 PM   #13
jeremywes
jeremywes's Avatar
Drives: 2012 Camaro SS
I would get an oil change immediately before it blows up
Just kidding
jeremywes is offline   Reply With Quote
