![]() Drives: Camaro 2SS LS3 Join Date: Jan 2013
I had a car accident with my 2011 Camaro 2ss and i have to replace some parts. so i was thinking to buy after market parts instead of OEM. I'll list the parts that need to be replaced and i need your advices for what kind of upgrades i can do instead of the OEM parts.
1_ Rear Wheel Bearing & hub assy, r&r 6.2L (Right) 2_Knuckle Assy, r&r (Right) 3_Rear Stabilizer Bar Assy, 4_Rear Lower Control Arm, (Right) i also want to lower the car if you have any advices of what kind of spring i should get. Much appreciated, Heemo |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2013 2SS/RS/1LE Join Date: Apr 2010
A few things to note. The insurance will only pay for the OEM replacement (price). And if you go aftermarket, you will need to by some of those parts in pairs. Not just the one that is damaged. So more money out of your pocket.
In any event, which parts get upgraded will depend on how the car is used and what problems (if any) you are having with the handling. From what I've seen posted, the parts you have listed are far down the upgrade list. Meaning there are many other parts that would be upgraded/replaced to change the handling before those parts. |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: Love the one you're with Join Date: Sep 2009
Do you only plan on lowering the right rear? I guess I don't get what you're asking. Why not just get the car fixed then worry about modding.
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: Varies Join Date: Dec 2009
