Old 04-29-2013, 11:35 PM   #1
LS3 Handler
I love the LS3
LS3 Handler's Avatar
Drives: 2010 IOM 2SS Manual
Water Methanol Injection
I see alot of F/I vehicles running Water Meth injection to lower the temps of the air intake because of the heat caused by pressureizing the air. Would a water meth kit help a vehicle that is N/A?
LS3 Handler is offline   Reply With Quote
Old 05-22-2015, 10:22 PM   #2
v6maro
v6maro's Avatar
Drives: 2014 camaro
Someone please answer this
v6maro is offline   Reply With Quote
Old 05-22-2015, 10:27 PM   #3
1KillerSS
Too much is never enough!
1KillerSS's Avatar
Drives: AGP TT SS [COTW] 4/20/15
Send a message via Skype™ to 1KillerSS
Waste. Useful if you are pinging on pump gas, A nitrous shot would probably be more effective.
Build thread
http://www.camaro5.com/forums/showth...55#post8107855
1KillerSS is offline   Reply With Quote
Old 05-22-2015, 10:36 PM   #4
1KillerSS
1KillerSS's Avatar
Also, you have to realize that, on a turbo car the air is being compressed, as you know the more you compress air the hotter it gets, The problem with an NA car is when you spray water in you are taking up a large amount of space for water that could be taken up with air to make more HP. So even if you did spray cooler water in, the change in air temp would be offset by the percentage of water to air ratio going down less air less HP.
The reason its such a benefit in a FI car is, for one temps, but also detonation.
Build thread
Old 05-23-2015, 01:25 PM   #5
IneedAZ
IneedAZ's Avatar
Drives: 2017 ZL1 A10 & 2021 BMW M340i x Dr
I had thought about adding to my nitrous setup...still on the fence on it.
Sold 2012 2LT RS 12.3@112 old setup
Sold 1967 Camaro Pro Street. Ran 10's mild BB on NOS.
2017 HyperBlue ZL1 A10 ** Born 3/17/17**Delivered 4/08/17
2020 Build: Mag2650, BTR Stage2, NW103, BG, 14% lower, 90mm upper, ARH 2" Long system w/no cats, SW Legend mufflers. **807hp/762tq on 93 gas** and **848hp/792tq on e47**
Sold 2018 (Go Mango) Dodge Charger Daytona 392 Daily Driver
Daily Driver 2021 BMW M340i Xdrive
IneedAZ is offline   Reply With Quote
Old 05-23-2015, 01:47 PM   #6
MagnumForceGB
MagnumForceGB's Avatar
Drives: Fastest 2010 Camaro V6
It can increase your octane rating so you can add more timing, but if you spray too much you will need to remove fuel so you don't run too rich. You would also need to put an IAT sensor after the nozzles to see the cooler intake temps.
Camaro V6 = 11.268 @ 120.11
MagnumForceGB is offline   Reply With Quote
Old 05-23-2015, 02:55 PM   #7
Jason@JacFab
Drives: 2016 1LT RS Camaro; 72 Chevelle
Send a message via AIM to Jason@JacFab Send a message via MSN to Jason@JacFab
I don't know a whole lot about nitrous, but isn't it already "cold" as it comes out? 12.3! you're really starting to get down there!
Jason@JacFab is offline   Reply With Quote
