Old 05-01-2013, 02:33 PM   #1
SSMickey
SSMickey's Avatar
Drives: 2010 IBM 2SS
1LE diff fluid
About to install my 1LE diff. I got 2qts. of 75-90 from the dealership. It says the friction modifier is already added. This is the same fluid that is factory filled in the ZL1 and the fluid that is called for in the rear axle chatter TSB. Is this the proper fluid for this diff and how much do I use? The dealer is saying 1qt. which seems low.
ProCharger P1X, Vengeance Racing Kaotic Cam, ARH Headers and Exhaust with Borla ATAK mufflers, MGW Shifter, MTI Drop Springs, Forgeline RB3C Wheels, 3.91 gears, Night Owl LED Control System
SSMickey is offline   Reply With Quote
Old 05-01-2013, 09:38 PM   #2
Midnight Rat
Midnight Rat's Avatar
Drives: SS 1LE
I was told the fluid for the zl1 is the incorrect one. Not compatible withe the seals. I used gm oil and then added the gm additive. 1qt will fill it unless you spill some. Your owners manual will also say 1qt.
Midnight Rat is offline   Reply With Quote
