05-01-2013, 07:28 PM | #1 |
Drives: 2013 Chevrolet Camaro 2SS/RS 1LE Join Date: Mar 2013
shift points
What RPM do you all shift at?
I just got my 1le and I can shift from 2nd to 3d smoothly, but 1 to 2 and 0 to 1 aren't as smooth...what rpms do you shift at? |
05-01-2013, 07:39 PM | #2 |
Drives: 2013 Camaro SS 1LE Join Date: Apr 2013
Bout 2k cruising around town. Just gotta be smooth with the clutch
05-01-2013, 08:05 PM | #3 |
Correct me if i'm wrong, but i believe the tranny is set so it won't let you shift into 1st at certain speed or rpm. 1st to 2nd may be getting you because of the skip shift.
Light em up
05-01-2013, 08:20 PM | #4 |
Drives: '13 AGM 2SS/RS 1LE, 1 of 139 Join Date: Apr 2011
Yes, I suspect that you are experiencing the "skip shift" feature that is designed for fuel economy when you shift from first to second (forces shift to fourth).
The remedy is simple...buy and install (simple) a skip shift eliminator, and/or, wind your rpm's up a bit more between shifts and "drive it like you stole it." |
05-01-2013, 08:33 PM | #5 |
Drives: 2013 camaro 1le Join Date: Sep 2012
You have to rev Mach when down shifting so the gears don't mesh. Just blip the throttle before you let out the clutch when downshifting.
05-01-2013, 08:33 PM | #6 |
Our clutchs is made with levy to hold in the clutch slightly when rollin in first..in simpler terms pretty much
when you take off in first don't completely let off the clutch until you're at about 7/8 mph and the same for second until you're around 11/12 mph you'll feel a difference in the smoothness. and eventually it'll be much more smoother after it breaks in |
05-01-2013, 08:49 PM | #7 |
Drives: 2013 2SS LS3 Join Date: Feb 2013
not sure if the 1LE clutch is any different from the 2SS but I find the Camaro's clutch easy to engage smoothly compared to the other cars.
