Old 05-04-2013, 06:52 PM   #1
Minge
Drives: 2013 2SS
At what pressure will the tpms trip
Anyone know what the lowest pressure you can run without tripping the tire pressure monitoring system? I have a new camaro with lowering springs and it rides much nicer at lower tire pressures but was wondering how low I can go without tripping the sensors.
Minge is offline   Reply With Quote
Old 05-04-2013, 07:17 PM   #2
2010SSRSM6
2010SSRSM6's Avatar
I think the low tire warning on the DIC comes on @ 32 psi, but don't quote me on that. I might me thinking of the onstar warning from the e-mails.
Old 05-05-2013, 01:18 AM   #3
Dizzy82
Dizzy82's Avatar
Drives: 2011 1LT/RS A6 RJT SuperCharged
I had a slow leak and my sensor tripped around 26psi.
BMR sub frame brace, BMR tunnel brace, LSR sways, LSR CM ca & tl, Sphon ExD el, GM tower brace, Megan EZ Streets, Goodridge Stainless Steel Braided brake lines, PowerStop D/S rotors & pads, Doug Thorty Ceramic Shorties, Magnaflow x-pipe, MRT V2.0, KICKER PowerStage sub & amp, Infinity speakers & tweeters, Viteese Throttle Controller, Viteese Paddle Shifters, ACS T2 Splitter, ACS T2 Ports/Quad LED lights, VDI kit, Havoc diffuser, IPF ECU/TRANS tuned, IPF/KPE Supercharged. 364RWHP/297RWTQ
Dizzy82 is offline   Reply With Quote
Old 05-05-2013, 06:54 AM   #4
nealdiwes
Drives: 2011 camaro ls
The Onstar reports give you a warning at 32LBS.
nealdiwes is offline   Reply With Quote
Old 05-05-2013, 07:49 AM   #5
bigbob11
bigbob11's Avatar
Drives: 2012 2SS
Funny you should ask, on my way home this morning @29 psi right rear tire came in alarm
bigbob11 is offline   Reply With Quote
Old 05-07-2013, 12:30 AM   #6
ss04flores
2012 Camaro SS
ss04flores's Avatar
Drives: 2012 camaro ss
Anywhere from 5-7 over or under the psi it's suppose to be at
_________________________
2012 IMB CAMARO SS
ss04flores is offline   Reply With Quote
