Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Members Classifieds - Parts for sale or wanted > Members Classifieds - Non-Automotive
Old 05-09-2013, 11:46 PM   #1
Bradrulz
Drives: 2011 Camaro 1LT IOM
Battery Tender 2-Bank Battery Management System
Selling my Battery Tender 022-0165-DL-WH 12-Volt 2-Bank Battery Management System. Is in like new condition with all parts. Believe I still have original box and instructions. Asking $70 shipped to your door (within USA). Accept PayPal payment only. Will get some actual pictures on Friday or Saturday. Picture attached is model I have.
Information:
The Deltran Battery Tender 12-volt/1.25-amp 2-Bank Battery Management System is the simple solution to the challenge of keeping multiple vehicle batteries optimally powered when not in use. It is able to charge any two 12-volt lead-acid batteries, including standard and sealed AGM and Gel Cell battery types and is also designed to utilize a 3-step charging program and safely function in a fully automatic mode. Taken together this makes the Battery Tender 12-volt/1.25-amp 2-Bank Battery Management System an excellent means of ensuring that your batteries are fully charged and ready to go when you are.
Safe, simultaneous 3-step charging of up to two batteries with automatic float mode.
View larger.
Charge any lead acid battery, including AGM and gel cell.
View larger.
Safe, 3-step Battery Charging
The Battery Tender 12-volt/1.25-amp 2-Bank Battery Management System is much more than a trickle charger. Utilizing a 3-step charging program (initialization, bulk charge and float mode), it allows users to simply connect the charger to up to two batteries, either in or out of a vehicle and forget about it until you are ready to use it, with the confidence that the batteries in all four vehicles are being maintained at optimal performance levels. This makes it perfect for seasonal and recreational vehicles like motorcycles, jet skis, ATV's, snowmobiles and more. It is also safe for your battery because it utilizes advanced microprocessor technology that automatically switches its output voltage to a storage or float level. This feature eliminates the need to worry about the damaging effects of overcharging, and the resulting need to check on the condition of a charging battery. If or when the battery voltage drops too far under load, this same smart technology resumes output power and the charging cycle begins again. The unit also features sparkproof connectors, short circuit and reverse polarity protection, an easy to understand charging status LED indicator for each charging bank, durable lightweight construction and almost no current draw from batteries connected to it.
Key Features:
Two independent charging stations, each providing 12 volts/1.25 amps.
Complete 3-step charging program (initialization, bulk charge and float mode).
Microprocessor controlled constant current that automatically switches to float/maintenance voltage after fully charging the battery.
Perfect for all AGM (absorbed glass mat), sealed maintenance free and flooded batteries.
Solid state two color LED indicates stage of charger.
Spark proof and reverse polarity protected.
Temperature compensated to ensure optimum charge voltage according to ambient temperature.
MRT2.0 with Helmholtz Pipes, Cold Air Inductions CAI, 4-Pack Gauges, Flat Black Stripes, Added Spare Tire Kit, Elite Catch Can, Chrome 20" Wheels, HUD, ABL Doors, GM Dovetail, Matte Black Gills, Rear Fascia Blackout
Bradrulz is offline   Reply With Quote
battery charger, battery tender, deltran
