Old 05-10-2013, 09:47 AM   #1
caverman
caverman's Avatar
Drives: '69 SS Convertible
Best place to get a '12-'13 rear drop link?
Well....heard some noise in the rear of my car backing out of the drive way so I decided to look under the car to see if I noticed anything out of the ordinary. Sure enough my passenger side drop link's bottom bolt came off and it caused the link to push up and become disconnected from the LCA.
I just have the stock '12 - '13 links for an FE4 suspension. Anyone have a suggestion on a good place to get one? I'm sure I can go to a dealer but they typically charge a bit more.
Build Journal
Old 05-10-2013, 12:39 PM   #2
jeremywes
jeremywes's Avatar
Drives: 2012 Camaro SS
I know my local Ace carries a large assortment of grade 8 bolts but not sure if they will have anything that long
jeremywes is offline   Reply With Quote
Old 05-10-2013, 02:02 PM   #3
caverman
caverman's Avatar
I'm missing the lower rubber piece as well.
I found one at a local dealer for $25. I'm going probably swing by and pick that up tomorrow and fix the car.
Build Journal
Old 05-10-2013, 02:23 PM   #4
JDP Sales
JDP Sales's Avatar
Drives: Chevys at the limit
That's not bad. We do the set for just under 40 but you would still be looking at shipping.
Best regards,
Tyler
888-308-6007
Old 05-10-2013, 02:45 PM   #5
caverman
caverman's Avatar
I'm only looking for one. The Driver's side is still in tact. Passenger side lower nut came loose so the lower rubber is missing as well. I still have the bolt and the plastic shaft.
They are actually $23.33 ea + tax at Classic Chevy in Grapevine.
Actually, I was thinking about calling Jordan to see what he could do for me.
Build Journal
Old 05-10-2013, 02:46 PM   #6
JusticePete
Drives: Camaro Justice
Take it and use a drop of LocTitie this time around.
Old 05-10-2013, 02:49 PM   #7
caverman
caverman's Avatar
LOL...trust me, that's in the plan this time. I should've known better the first time. I put blue Loctite on pretty much everything else.
Build Journal
Old 05-10-2013, 02:51 PM   #8
caverman
caverman's Avatar
Now I'm just wondering if it was not attached when I did my track day a few weeks ago.
Guess I'll have to go back and try again.
Build Journal
Old 05-10-2013, 04:40 PM   #9
jeremywes
jeremywes's Avatar
Loctite AND locking nut plus the chuck norris threatening stare
Old 05-10-2013, 04:44 PM   #10
caverman
caverman's Avatar
One last question....can one of the vendors verify for me the part number for the FE4 rear drop link? The dealer was asking me for my VIN which obviously wouldn't match. I just want to verify that this guy was able to look up the correct part # before I drive 30 min away to find out it was the wrong part # and he doesn't have it in stock.
He gave me #22761221
Build Journal
Old 05-10-2013, 04:50 PM   #11
JDP Sales
JDP Sales's Avatar
That's it!
Best regards,
Tyler
888-308-6007
Old 05-10-2013, 04:55 PM   #12
JusticePete
That is correct. I have one here on my desk. How badly do you need it? Saturday delivery? Ground Texas to Texas is two days. PM your ship to address and shipping preference. Don't worry about the cost. We'll get even on your next suspension upgrade
Old 05-10-2013, 05:42 PM   #13
caverman
caverman's Avatar
PM sent....
Build Journal
Old 05-10-2013, 10:26 PM   #14
TBone
Negative Camber Junkie
TBone's Avatar
Drives: 2010 1SS LS3/6MN ABM 1 of 23
PETE to the RESCUUUUUUE!!!
T.
"Horsepower is something that looks great in a Magazine article, but suspension is what actually gets you around the track fast.." Jack Olsen
The drag strip is like sniffing glue, it's cheap, it's a decent buzz, it doesn't last long and they are all the same.
Road racing is like China White Heroin, the buzz is stronger, the high lasts for hours, it's extremely addictive and they are all different.
I can't wait for my next
Track fix.
DA HAWKS OWN DA CUP!!!!!
TBone is offline   Reply With Quote
