Old 05-13-2013, 12:03 AM   #1
Bradrulz
Drives: 2011 Camaro 1LT IOM
Reminder when changing oil . . . Lesson learned
Just thought worthwhile of a reminder as I was Dumb@ss today and when changing my oil I had the car pulled up on the race ramps, all my tools gathered, some cardboard down, oil drain pan down ........ Then removed the drain plug.......and the morning went to hell. Forgot to open the valve on the oil drain catch pan/bucket and ended up with about 4 quarts of old oil on the concrete garage floor before getting it open.
Told my 5-year old daughter ...... Let this be an example of when you are trying to do something quickly and not paying complete attention I usually results in it taking 10 times longer. Was quite a pain trying to get all of that off the garage floor.
MRT2.0 with Helmholtz Pipes, Cold Air Inductions CAI, 4-Pack Gauges, Flat Black Stripes, Added Spare Tire Kit, Elite Catch Can, Chrome 20" Wheels, HUD, ABL Doors, GM Dovetail, Matte Black Gills, Rear Fascia Blackout
Bradrulz is offline   Reply With Quote
Old 05-13-2013, 12:20 AM   #2
KlugSS
Guest
Posts: n/a
Sucks man.
I have dropped the drain plug into the pan and it always seems to fine the hole and plug it. Luckily I can usually grab it before it over flows.
Old 05-13-2013, 12:26 AM   #3
CHMSC
ROAD COURSE JUNKIE
CHMSC's Avatar
Drives: 2012 SS/RS LS3
that sucks man, we all have those ooh chit moments.
CHMSC is offline   Reply With Quote
Old 05-13-2013, 12:34 AM   #4
now that would definitely ruin the day
Old 05-13-2013, 12:47 AM   #5
Bradrulz
Definitely did . . Was at about 6:00AM to so definitely ruined the whole day.
Old 05-13-2013, 09:32 AM   #6
SPCBA
Drives: pleather and Chiclets
i did the whole plug goes back into the hole and plugs it in a friends garage. was so embarassed. i now pull the plug and set it aside instead of setting in the pan.
SPCBA is offline   Reply With Quote
Old 05-13-2013, 11:40 PM   #7
CHMSC
ROAD COURSE JUNKIE
CHMSC's Avatar
I will share one with you lol
I went to bleed my clutch, put a hose in a water bottle as my catch can. Worked great till I took it off the clutch bleeder valve. It started spraying brake fluid all over me, I neglected to make room for the bottle to breath, so the whole time I was bleeding the clutch it was pressurizing the bottle. Lol
Old 05-14-2013, 01:29 AM   #8
ryan's camaro
Taeng
ryan's camaro's Avatar
Drives: Fast
Hence why I don't use those types of containers to collect my old oil.
Instead, I use one of those large oil container jugs with a traditional cap. I open it up and stick a giant funnel on the top of it. Oil comes out and directly into there. I also put a shallow tub next to it to catch leftover oil drips when the flow slows, changes direction, and drips slowly.
Great thing is, since it is a jug with a cap, there is no risk of plugging up and transport is clean and easy since the oil is all contained within and sealed with a plastic cap.
ryan's camaro is offline   Reply With Quote
