Old 05-16-2013, 06:30 PM   #1
NYblack1le
Drives: 2018 1SS 1LE
Front Speakers
Unhappy with the sound coming out of the stock BA speakers. Was wondering what needs to be done to simply replace the front door speakers. Dont want to do anything crazy just clear up the sound a bit.
NYblack1le is offline   Reply With Quote
Old 05-16-2013, 06:44 PM   #2
2010SLVRBULIT
2010SLVRBULIT's Avatar
Drives: G5(LLT) & C6(LS3)
..talking removal, or replacement brands(ie MB quart, JLs, Polks)?
Old 05-16-2013, 07:05 PM   #3
TwentyTen2SSRS
TwentyTen2SSRS's Avatar
Drives: 2010 2SS/RS
Going to have to take the door off... isn't the easiest thing (in my experience).
TwentyTen2SSRS is offline   Reply With Quote
Old 05-16-2013, 08:19 PM   #4
JimE
JimE's Avatar
Drives: 2013 2SS/RS/1LE
Door panel, not the door. In any case, removal is easy. Putting it back on is the challenge.
And speakers themselves won't make that much difference with the factory amp in place. Replacing the amp will make a better difference than simply swapping the front speakers.
JimE is offline   Reply With Quote
Old 05-17-2013, 07:06 AM   #5
mbober99
mbober99's Avatar
Drives: 2011 Camaro SS
When you buy new speakers, you might want to check on tweeter size before buying. I bought some MB Quart QS216's and the tweeter is larger than the pod the original BA tweeter is mounted in at top front of door panel, so beware of that. I am in the process of making my own tweeter pods to replace the originals. You will need some adapters for the 6 1/2" door speakers also, and you may want to get those from ******** .com.
mbober99 is offline   Reply With Quote
Old 05-17-2013, 07:25 AM   #6
Ohten
Ohten's Avatar
Drives: Granite Crystal Challenger SRT
Since I had done the speaker swap before I removed the screws and just popped the door panel loose and reached in and removed the bolt holding the speaker and removed the speaker without removing the door panel.
Ohten is offline   Reply With Quote
Old 05-17-2013, 08:44 AM   #7
Chris-10
Chris-10's Avatar
Drives: 2ss/rs vr 6m
Pretty much this^^^
Replace the factory amp, it'll make a huge difference and if your still not happy then change the door speakers. Taking the door panel off is easy. Takes about 3 minutes. I've had mine off several times.
Old 05-17-2013, 08:57 AM   #8
family man
Drives: .
Pretty much this^^^
That's how I am working on mine. Did the amp and fark harness and added a 10 bazooka tube. Thumps like crazy and does sound a lot better now. Next is to change out the speakers, just need to find the time. Been busier than a one legged man in a butt kicking contest lately.
family man is offline   Reply With Quote
Old 05-17-2013, 10:53 AM   #9
Twilborne
Twilborne's Avatar
Drives: 2013 Blue Ray Blue 2LT
http://www.camaro5.com/forums/showth...front+speakers
These may help you out.
Twilborne is offline   Reply With Quote
Old 05-17-2013, 11:26 AM   #10
Iwantone2
Voice Of The Voiceless
Iwantone2's Avatar
Drives: CGM 1SS RS
Old 05-21-2013, 08:49 PM   #11
FAT-SS
unBALAnced-10
FAT-SS's Avatar
Drives: 2010 Camaro SS
Relocated Tweeters to just above the woofers on doors
I upgraded my door speakers from the JL Audio C2-650 Components to the C5-650 Components. I didn't like the way the speakers sounded with the woofers & tweeters being so far apart so I mounted the tweeters closer to the woofers on both doors. Sounds a lot better now, I think.
FAT-SS is offline   Reply With Quote
