Old 05-16-2013, 11:39 PM   #1
Nighthawk89
Nighthawk89's Avatar
Drives: 2011 Camaro 2Ss M6
Power Steering, Coolant, Brake Flush?
How beneficial is it for me to get any one of thoes three flushed? My 2SS m6 has 26,000miles on it. Also, a tranny fluid change?
Nighthawk89 is offline   Reply With Quote
Old 05-16-2013, 11:59 PM   #2
yellowrs
Drives: 2010 SS 426 V8 M/T
Changing the fluids/flushing them never hurts if you do it yourself.
Don't pay outrageous money having it done.
I personally only would do the transmission and coolant flush.
yellowrs is offline   Reply With Quote
Old 05-17-2013, 12:07 AM   #3
Juiced1
Drives: 2012 2SS CAMARO 45th
Dextron 3 trans fluid is good for 100k. If you're hard on your trans and it sees a lot of increased temps on regular basis I'd recommend you change it at 50k. Modern coolant is good for 50k. So I'd say you're half way there.
Juiced1 is offline   Reply With Quote
Old 05-17-2013, 12:53 AM   #4
tonyko1
Banned
Drives: 2012 Camaro 2SS/RS Convertible, IBM
Just follow your 300 page + owner's manual.
If you are driving the car like a regular commuter, i.e., not drag racing or "drifting", nor doing burnouts or such, you will be fine.
God bless we have nothing else to be worried about.
t
tonyko1 is offline   Reply With Quote
Old 05-17-2013, 08:54 AM   #5
clg_98ta
clg_98ta's Avatar
Drives: 2010 Camaro 2SS
With your M6, its important to replace the brake fluid at least annually - otherwise you'll start having clutch problems (unless of course you've installed a separate clutch reservoir).
Coolant - every 5 years regardless of mileage. Dexcool turns to sludge after that (search for "Dexcool lawsuits" if you don't believe this).
I never really change power steering fluid unless I have a problem...
