Old 05-18-2013, 11:52 AM   #1
Bornluckee13
I fly
Drives: 2010 2SS, Stick, Cyber Gray
Ti shims?
Heard about titanium brake shims, what's the purpose of these? Reduced heat transfer to caliper/fluid or even wear on pads? I'm pretty decent at smoking breaks on the track and am all for anything that actually helps with heat! Thanks Y'all,
LJ
Originally Posted by kmcd View Post
You mean all those decades I drove a car without an onboard computer, I was cheating death?
There are only two options in life. Fight or flight. Most people run. Almost all people run. But not us. The difference between us and everyone else is that we run towards the gunfire. And that makes all the difference.
Bornluckee13 is offline   Reply With Quote
Old 05-18-2013, 12:28 PM   #2
Synner
Drives: cars
Reduces heat transfer from pad to caliper pistons/seals/fluid. It will get saturated with heat after a while but for most people and basic track days they would work ok and reduce the inevitable. I would work on brake ducts first and optimizing your rotor/pad selection before investing in something like this.
Only negative I know of is they can reduce the firmness of your pedal to some degree.
Old 05-18-2013, 12:48 PM   #3
Bornluckee13
I fly
Thanks man, brake ducts are in process thanks to aircraftspruce.com! Will probably get the RB two piece rotors when mine die as well. Who new stoping would make you faster?!? Lol
Old 05-18-2013, 02:28 PM   #4
TBone
Negative Camber Junkie
TBone's Avatar
Drives: 2010 1SS LS3/6MN ABM 1 of 23
Check this out,
http://hardbrakes.com/
T.
GO HAWKS!!!
"Horsepower is something that looks great in a Magazine article, but suspension is what actually gets you around the track fast.." Jack Olsen
The drag strip is like sniffing glue, it's cheap, it's a decent buzz, it doesn't last long and they are all the same.
Road racing is like China White Heroin, the buzz is stronger, the high lasts for hours, it's extremely addictive and they are all different.
I can't wait for my next
Track fix.
DA HAWKS OWN DA CUP!!!!!
TBone is offline   Reply With Quote
Old 05-19-2013, 04:17 PM   #5
Denis
Denis's Avatar
Drives: 2010 SS
Are these someone worth getting on a street car that will see the track only a few times a year?
Old 05-20-2013, 12:21 AM   #6
Synner
Drives: cars
No.
Old 05-20-2013, 03:48 AM   #7
Denis
Denis's Avatar
Drives: 2010 SS
Originally Posted by Synner View Post
No.
Lol short and sweet
